December 02, 2025, 07:47:40 PM *
Author Topic: how to clean air variable capacitors - dirt on plates  (Read 15022 times)
« on: November 11, 2008, 09:43:14 PM »
So the time is coming for starting on the frankentuna..
Several nice beefus caps, but the otherwise good aluminum plates have the grime of the ages on them and have a gray-brown dirty appearance, and I can't get in there with any kind of brush or rag.. I'm not sure ignoring this and relying on "RF cleaning" is an acceptable method!
The picture is an example of how filthy these are. It's dirtier than it looks, it is not just dust that could be blown off with air; it seems to be on there pretty good.
What can I do to clean these things? (I do not have a dishwasher)
W1EUJ
« Reply #1 on: November 11, 2008, 09:58:02 PM »
Hot water, soap, foam brush. Airdry by the hot water heater/boiler for a day, then oil.
« Reply #2 on: November 11, 2008, 10:34:46 PM »
Hmmmm, I've had good luck using CIP-200 and water, (about 25% strength.) About 15 minutes and a good flushing with water. Also, 1 part ammonia, 3 parts water works good and is the typical solution for cleaning jewelry, (your jeweler will tell you it some high price stuff Wink ). You can use some of your different metal cleaners in a spray bottle but they have a tendancy to streak. Go with something you can dunk in a bucket. Have 2 buckets, one for cleaning and one for rinse. Gud Luck in the Corntest Cheesy
VE3GZB
« Reply #3 on: November 11, 2008, 10:51:58 PM »
I used to have one old salvaged variable capacitor from a late 1920s/early30s AC powered radio I had as a teenager, and this capacitor was horribly rusty! The plates, the end plates, you name it!
I used that Rust Remover you can buy for your car (some kind of acid). It cleaned it up right quick! Then just rinse with cold water and dry with a hair dryer!
« Reply #4 on: November 12, 2008, 07:49:31 AM »
yessir Patrick ... I have found that I indeed have variable capacity, depending upon excitation! ...73 ...beefus
KD3CN
« Reply #5 on: November 12, 2008, 08:22:10 AM »
I asked for advice on this a while back.  Got lots of good info, and entertainment to boot!
http://amfone.net/Amforum/index.php?topic=10285.0
73, Karl
« Reply #6 on: November 12, 2008, 08:57:32 AM »
I've taken them all apart and cleaned each part. This way you can buff out the flash over marks. Dish washer soap in a pail of hot water works well.
« Reply #7 on: November 12, 2008, 10:43:13 AM »
a run through the lowly dishwasher with dishwasher detergent does wonders for aluminum and ceramic...
after that you can touch it up and relube as needed...
oh... get thee a dishwasher - they're free outside of most larger appliance stores around here (in the back) not much ever really goes wrong with them - just grab a few of the same brand and almost all the parts interchange!  Grin
the alternative is to soak and agitate them in a bucket (plastic) with very hot water and a good dose of liquido dishwashero detergento... about an hour or so ought to make it perfectly wonderful. You will loose the decal though... unless you don't dunk that part...
Also the alkaline cleaners (Mean Green, Thunderbolt, and "degreasers"/floor strippers) will clean up aluminum and the ceramic as well... spray on, rinse under hot water, repeat as needed... pretty good results that way too...
k7yoo
« Reply #8 on: November 12, 2008, 11:04:00 AM »
I am sure there are a gazillion ways to clean variable caps--but the easiest and cheapest is Scrubbing Bubbles. I usually put the cap (or radio) right in the bathtub or shower, foam it, let it sit for a few minutes, and rinse with hot water. You can use a hair dryer or set it in front of the heat register to dry. Relube and away you go. What's great about this is that your shower or tub gets cleaned at the same time. If you want to really be efficient the cap can replace your regular rubber ducky and you can be entertained and clean at the same time!
Seriously though, I have used this stuff to clean all of my B'cast xmitters, radios, etc. Bare metal brightens right up. DO NOT let it stand on paint though--it can streak and EFJ paint runs right off.
« Reply #9 on: November 12, 2008, 11:31:16 AM »
I would be careful about aggressively washing the ceramic parts too much, such as by running through a dishwasher.  I distinctly recall warnings from EF Johnson or National (maybe both), years ago, that the unglazed ceramic insulation in their rf components is coated with some kind of moisture proofing oil or wax, and that solvents or too much scrubbing may remove that protective coating.  Unglazed ceramic is hygroscopic, meaning that it absorbs moisture from the air, and this degrades its insulative qualities, possibly leading to failures.  First it arcs over, which then leaves carbon tracks that are impossible to remove, and sometimes the ceramic actually cracks.
I would disassemble the capacitor, cleanse the ceramic with a cloth wetted with a mild detergent solution, then clean and buff the plates in a separate solution.
I vaguely recall that the protective coating is some sort of silicone product.
« Reply #10 on: November 12, 2008, 11:58:43 AM »
Gee I wonder if tile grout sealer would work???
k7yoo
« Reply #11 on: November 12, 2008, 01:12:41 PM »
I haven't experienced any problems with cleaned components and have applied this treatment to at least 6 KW matchboxes and innumerable high power tank components. Most capacitor and switch parts are unglazed (unlike standoffs), and I have seen few with any coating. My guess is that most of the junk we are saving is so old that the benefit of cleaning the crud off far outweighs any other factors.  Carbon tracked switches can be saved by glass beading--I have saved at least half a dozen high power switches this way. I do agree that a sealer would be a nice touch. A light coating of thinned Q dope or even Conformal coating would work well. Keep it thin to permeate the ceramic. I haven't tried grout sealer but the sealing properties may be beneficial--it is also very thin. I am not sure about the dielectrics though--should be OK.
k3zrf
« Reply #12 on: November 12, 2008, 08:23:46 PM »
And if all this advice doesn't work put 'em on the firing range like our northwest friends!
dave/zrf
« Reply #13 on: November 12, 2008, 09:13:13 PM »
Yes    Yes...The tube shoot is this weekend....Look for us on 75 and 160 ...Pictures will follow...
STEVE
« Reply #14 on: November 12, 2008, 10:58:22 PM »
evil, shooting tubes.. even TV set tubes..
k7yoo
« Reply #15 on: November 13, 2008, 09:59:41 AM »
I might be there next year Steve. I have two large boxes saved up for the occasion-4-1000's, 4-400's, 250 th's, and more!
Skip
k3zrf
« Reply #16 on: November 13, 2008, 06:30:31 PM »
STEVE
That sounds like a lot of fun. Seems this time of year I think about you and the event.
We used to shoot at a Flying"A" horse sign behind DUQ's with 12ga slugs years ago.
The sign was on the ground, not at the gas station
dave/zrf
w8khk
« Reply #17 on: November 13, 2008, 06:48:10 PM »
Skip
These dead tubes make very nice lamp bases...  Shame to blast them to pieces.  Need a sign to shoot at?  The local TARGET store seems to fit the bill....
« Reply #18 on: November 13, 2008, 07:02:52 PM »
I have some 300Bs if you want them.
Skip
K1DEU
« Reply #19 on: November 13, 2008, 07:05:31 PM »
No dishwasher; Car Wash time !
« Reply #20 on: November 13, 2008, 07:28:10 PM »
Hope they are crapped out.  Otherwise, the audiophools would cry their eyes out.  Actually, they would make better class-B driver tubes than 2A3's, so save them if they are still good.  Of course, a good 300B would fetch enough on ePay to buy a brand new four-by-one.
WA1HZK
« Reply #21 on: November 13, 2008, 08:20:51 PM »
I run all that stuff through the dishwasher. Put it in the oven at the lowest temp possible to dry.
Works Pissa.
Keith
www.criticalradio.com
www.criticalbattery.com
www.criticaltowers.com
www.criticalresponder.com
« Reply #22 on: November 14, 2008, 09:16:48 PM »
We always seem to forget the Italian way to clean capacitor plates.........and that is a big pan that you can immerse the capacitor completely in tomato sauce and boil in this sauce for a couple of hours. The plates look like new. And then the usual rinsing and drying in a warm oven for a couple of hours.
THEN invite your friends over for one helluva Italian meal re-using this sauce.
The first paragraph is true.........the last sentence is not.
G'day
fred
« Reply #23 on: November 15, 2008, 03:28:01 AM »
Let WA1GFZ do an AQL test. If it passes HiPot, do nothing - install.
Page created in 0.06 seconds with 14 queries.
