December 08, 2025, 04:57:10 AM *
Author Topic: Somebody dropped off all this junk!  (Read 24773 times)
« on: August 16, 2008, 04:16:28 PM »
Check out this stuff I just found. One of the RF amps says "Jaws II" on it. They have 3CX3000A's for tubes. Also an audio processor and a dummy load of some kind.
http://www.bunkerofdoom.com/jawsii/
« Reply #1 on: August 16, 2008, 04:44:29 PM »
Been a while since anyone dropped off 'junk' like that here. Good find, er....haul?
« Reply #2 on: August 16, 2008, 05:24:50 PM »
one has to wonder what happened to Jaws 1.
Use Jaws for 75 as a lin yar and rape teh Henry for a HB rig.
I bet there are sum tall ships drooling over that Harris. I like my stock D-104's my own bad self.
« Reply #3 on: August 16, 2008, 07:33:37 PM »
That Jaws II is a pretty FB looking amp, although the tank coil looks a tad on the wambly side for a 3CX3000.
That Henry is a 13.56 MHz ISM amp, probably for sputtering, etc.
« Reply #4 on: August 16, 2008, 08:56:06 PM »
Boy if I could find a link for the The Tool Man Tim oooh ooh ooh...get a load of that Harris..Das Goot Schtuff.... Smiley
Ya got the makens of a FBOM station there OM....what's yer plans...there's alot of Help on this forum to walk you through a build up.  Smiley
« Reply #5 on: August 16, 2008, 09:12:34 PM »
JN, you jogged a memory cell loose when you said sputtering.  Shocked I used to run a vac sputtering unit when I worked for the heart pacemaker place. we deposited platinum thru holes onto each individual ceramic feedthru, hundreds at a time. This was in 1998.
To better serve its customers, in 1998 Greatbatch purchased Hittman Materials & Medical Components, the premier
producer of feedthrough connectors and advanced electrode coatings in the CRM industry.
I got out of there when Hittman got purchased. My boss was retiring and so was the owner, Hittman. I was the tail end of a 4 man engineering team and everyone thought they were going to move everything to NY. Lotsa rumors and so on. I actually drove from West Virginia to Columbia MD. every day for a year, but hit the road after that. Couldn't take the commute any longer.
the blue glow inside the vac chamber was cool as hell. tank was about 7 ft in diameter with a 5 inch viewing window in front. You tuned it by raising or lowering the platform to max out the current. I don't remember the power but it took 440 3 phase input IIRC.
I have no idea why I went into all that.  Roll Eyes
« Reply #6 on: August 16, 2008, 11:01:06 PM »
A new friend broiught me there treasures.
I'm not sure what to do with the Harris, never had anything like that before. It's obvious a FB piece, but got no tubes inside. It might clash with the RCA BA-6A compressor.
I really don't know what to do with all the audio stuff I have except connect it in a logical order till the rack is filled up.
I am confused on the Harris why I would want to select the "expand" function when transmitting. but it must be there for a reason.
There is also going to be stuff left over if I have to make room for the Harris. I'm going to have to evict, from the rack, the Marti compressor and CBS Volumax limiter along with the small 30W hi-fi amp I was going to use as the mod driver, and the CCTV surveillance monitor has to go.
Maybe I could run this lash-up based on what's here:
1.) Altec mike amp
2.) Kahn Symmetra-Peak SP 58-1A (for a bigger voice in AM-FM and TV broadcasting [TM]) -yet I see the Harris has + and - peak protection -but that is differnt, the Khan moves the peaks, the harris protectes against theit amplitude?
3.) Harris MSP100 processor (would it go here?)
4.) RCA BA-6A compressor limiter to set general the level (?).
5.) switchable in/out passive audio bandwidth filter and/or EQ to shape the response according to transmitter's modulation characteristic.
6.) Presto or Altec power amp to drive the modulator
7.) The modulator
Is this too much stuff? I've seen pictures of stations with -alot- of audio stuff.
« Reply #7 on: August 16, 2008, 11:32:31 PM »
Jaws 2 will do all the "processing" you need.
« Reply #8 on: August 17, 2008, 02:09:21 PM »
hey don't you give jaws a look over and then plug it in and drop teh maul? i got a funny feeling that that thing is gonna work.  Cheesy
« Reply #9 on: August 17, 2008, 03:58:14 PM »
Yeah I think you'e right Derb, I don't need any of that audio processing crap with JawsII. JawsII+plastic radio.. hahahaha! - But I was told it takes 200W to drive it all the way up, so it might be a job for the Viking I. And I think it has 4000V B+, I better be careful with it or I won't be posting any more. I bet it will run real cool on AM. No more burning up 8122's in the NCL2000. Soon as the weather cools off, I can load it up on the 40FT randome wire.
Jaws needs some dental work first. It needs a RF choke for the plate, a 25 ohm "fuse resistor" in the plate circuit, there are a few loose items, and also I was warned to carefully reform the electrolytics in the HV power supply. I have not opened that yet. Maybe this fall will be a good season of ham radio for me..
I was also shown these things below. I am going to try and trade for them if my friend will consider it. This is a "Norton" audio amp. I'm told they made some big amps, and this one used four 845's. It was suggested I could uses zero bias 838's, since the 845's are all taken up by the phools' SE class A amps now. It has a 500 ohm output. I have not yet found any "Norton" info on the www. This kind of thing makes me very interested. I just want to smell it; the smell of old radios. (yeah I know that is really the smell of mildew and PCB oil in wood, but whatever) I guess it qualifies as a Buzzard audio amp.
Ralph sez: Hey Norton!
« Reply #10 on: August 17, 2008, 04:19:21 PM »
Can you 'splain bout the coil? It's thin, but made of flat spiral, I thought it was about 3/16" wide. Is there not enough turns? There is a coil below, with more turns, not sure yet really how it is all conected.
« Reply #11 on: August 17, 2008, 05:07:22 PM »
I thought perhaps it was edgewound, in which case it's certainly up to the task at hand Grin
« Reply #12 on: August 17, 2008, 05:14:05 PM »
prolly got another coil that switches in for more L on 160. Are You Sure? that thing does 4KV on the plate? I'd blow no more than about 50 watts carrier into it after you give it a going over.
Re the plate choke: the one I got from Frontier Engineering for maul #1 is primo very top quality for 35 bucks on ebay. he has a store on there. You tell him what you need and he winds a custom job just for you upon price quote and approval. On a amp that big there's no way I'd try to stick some hamfest plate choke in there. You are now in the big strapper class with that amp. That means you will have to
spend a bit. take some measurements of the length you can fit in there. tell him you got the tube, voltage, current, etc. and he will fix you up. He can wind it on Delrin, ceramic, or teflon.
I got no connection with the guy but I dont think you're going to get a custom made plate choke better for less. you can even pick the color of the magnet wire, blue, green, yellow, etc. I got 2. I just told him I had 4 572B's @ 1800vdc 1000 ma max current 80-10 meters and he did the rest.
I am working like hell in the shack. Gotta get back to it. maybe some pix later.
www.freng.com/
« Reply #13 on: August 17, 2008, 07:32:10 PM »
Pat,
took another look at Jaws 2. Saw something - maybe nothing, but one or 2 of the mounting screws on the jennings vac cap looks a little askew to me, possibly like it took a hit. Get together with GFZ on here and see what he thinks of it, and rotate the knob on that mother
very tenderly until you figure out if it's just loose or someone wrenched on the cap knob with the name of Hambone.
Also, I dont know of a factory made tuner that would handle that thing into a 40 ft random wire. Not even a KW Matchbox. That thing with 4 KV on it assuming everything else is good on it is capable of more than 7~8000 watts peak on slopbukit and would run 21~2300 carrier on am all day long. ifn the iron is big enough, and it looks like it is.
That thing is too much fer a random wire. I think things would randomly start blowing up in yer shack real fast.
and it's got a electro stack at 4 KV? I believe I would be using some decent oil jobs and find a big ass swinging choke an change it over to choke input so you dont need so much capacity. Couple of good oils ....say;  total 20 mf @ 10 kv. Expensive but I wouldnt trust a electro stack @ 4KV.
You gotta pay the price to get out nice.  Cool
« Reply #14 on: August 18, 2008, 08:09:53 PM »
You can use Chinese 845s... they work quite well.
Of course 211s are also an option.
Perhaps even 813s strapped for triode.
838s and 805s are possible but check the plate Z differential if any.
         Nice finds!
                Geez, I have no friends by comparison...  Sad
« Reply #15 on: August 19, 2008, 08:47:40 PM »
Derb,
I had a good look at the mounting screws, they seem to be fine. It turns real nice but the knob is right up against the panel. The screws at the back end connector look askew, but the connector there is off the backend post of the cap. So it's askew. Nothing looked bent or broken. I was told the amo is now wired for 160M only, although I am not sure why the bandswitch is there, except it has taps on the coil, maybe for segments of the band? I have to investigate further in a couple weeks. Sure enough I will just tickle it at first once I have replaced the missing items. I have not even looked inside to see if it has a T/R switch. It is pretty well made for a HB amp. I have sen factory made ones that did not look as nice.
as for the tube, oh my.. How will I be sure to obey the 1500W rule? It's easy to reduce drive. I best come up with a simple peak measurement device once it gets resotred and comes off the dummy load (assuming there's anything left of that).
I believe I understand why it is good to use an overkill amp for regulation power levels. I recall an old article about a big linear amp commercially sold to hams, called the Elenco "commander". It used a 4-1000 in GG with 6KV on the plate. input 4KW PEP SSB, 1.5KW AM, 3-30MHz coverage, made in 1958-1959. The findings were that an amp capable of X output would have much less distortion at X/n output level.
« Reply #16 on: August 19, 2008, 09:02:18 PM »
Bear,
I didn't know 845's are still being made.
But I don't have that Norton amp yet. I maybe have to trade for it or buy it, so we will see. There might be some 838's available which are the zero bias similar type. Probably not popular with the audiophools since they need some grid current.
In the meantime, does anyone know how good these things are: collins modulation monitor and 26U-2 audio limiter?  They are not mine, I just have pics. I'm used to using a scope for mod monitoring.
« Reply #17 on: August 19, 2008, 11:38:54 PM »
a amp that size probably has a vacuum T/R switch as well. the bandswitch is for different bands. you dont need taps on a correctly designed tank to cover all of 160. More likely it was hacked in some manner and you will have to un hack it.
what are you going to do about your real problem? There's no tuner on earth that can handle that beast into a 40 ft random wire. Unless you improve your antenna situation you cant use it. you can test it into that huge dummy load though. Got a ready source of 220? That thing don't run on 110.
You're going to have to give the whole thing a good going over. Maybe more work than you wanna do, I dunno.
« Reply #18 on: August 20, 2008, 04:56:55 PM »
Are you sure that these mysterious things that showed up were not destined for the VORTEX??? Somehow these things get confused and show up on someone's front door.
Make a big wave on AM!!!!!
« Reply #19 on: August 20, 2008, 10:13:57 PM »
Bear,
<snip>
Ya, dee Chineze make 'em.
Buy 'em by the pallet or the container full...  Grin
Think there are several US distributors, including Electro-Harmonix.
Let me know if you need any Chineze toobes, or Ruskie tubes of the audio persuasion.
Anyone else too... just need to buy more than one or two usually... I am technically an OEM buyer from EH.
The 838 is a bit of sleeper, but most audiophiles who roll their own use the 845s in A2 anyhow... 211s also A2.
Part of the problem with the 838 is finding a bit of iron that will handle the snot/monkey swing from a pair... that being for 8ohm type iron, not mod iron.
<secret message>Btw, I'll be packing that thing this weekend for you...  </secret message>  Wink
« Reply #20 on: August 20, 2008, 11:26:19 PM »
Strangely it is wired for 120V and has a big-ass plug on it. It's a 30A or 50A RV type plug.  It is supposed to be rewirable for 240V, I am sure I will do that. It will be a fun project. You are right about the antenna. I have to put up a real antenna. But I will work on the amp now and try for the antenna in the coool weather of the fall, it will be fun and I kind of have to, if ya know what I mean.
I looked inside the accompanying dummy load. It's been hot. Someone or something has cooked up the 4300 watt dummy load.
Bear,
as for the 838's and 845's, looks good. I will know if I am getting the Norton amp this saturday. I found out what it is for. It is a chimes amplifier. Must have come from a church and played the bells. It is in a maybe 7FT black rack with a turntable, driver stage with 6B4's, and the rest has been shown. The front panel is beautiful and very dignified, just as something from church should be. Anyway I get to see it on saturday. I will judge the size of the OPT iron and if it looks like it will make 200W into 500 ohms then I'll try for it. That and an H pad should make rock solid well regulated driver to a pair of 3-500Zs.
« Reply #21 on: August 21, 2008, 10:11:21 AM »
pat,
does it still measure 50 ohms at the terminals? - and is it an oil filled load? if you take the covers off the PS at some point, snap some pix - I'd love to see the Iron in that thing.
I'm bored as hell - as have to stay down here at my dad's until SATURDAY. Urk. Urg.
Cant do radio work when you're never home.  Undecided
« Reply #22 on: August 21, 2008, 11:16:24 PM »
I would like to do that soon -open the dummy. I have not measured it, all I had time to do was hide it in the storage building with Jaws and Henry. It's air cooled by convection and has several racks each with several large resistors in it, maybe 1" diameter and 8-10" long. It's air cooled and has a grating I could peek through, and it looked like wire was exposed on some.
In looking at the ratings - 4.3KW AV - 13500V peak. I have no idea what it is originally for. Might not be 50 ohms regardless of the PL-259 connector, which would probably melt at 4300W.
I need to show some pictures of the parts I have been collecting for the "tuna" but it's a ways off, since the coily things will have to be driven by motors as they are pretty hard to turn. They make the one in the jaws look sissy. I have the motors but none of this has any limit switches, so I have to deal with that too. I think it will have to be built on a set of rack panels. and put in a cabinet. The vriable inductors on one motor shaft and the variable caps on another. I can use a big knife switch to place the caps on the TX side of the coild or the feedline side of the coils. the Balanced in/out, and a 5KW (1:1) balun will have to be bought and put at the front where the radio hooks up. So far I have two 0-15uH roller coils from a 10KW BC station, some non-matching fixed coils (need pairs), and a bunch of air variable caps, some 1000pF/3500V and some about 200pF and 5000-7500V. I hope to be able to have a heavy duty coax switch where I assume the position and pick from the tansmitters, and then just one cable going to the tuner about 30FT away by the wall, and have the ladder line go out from there.
I got this idea from "A Balanced Balanced Antenna Tuner By Richard L. Measures, AG6K" and "Home Brew Balanced Antenna Tuner by Philip KB4I", both of which appear here, where I have scurriously assembled some papers on antenna tuners into one document, without asking anyone's permission at all:
http://www.bunkerofdoom.com/lit/bal_xmit/HFbaltransys.pdf
(no one has complained yet)
I wish you didn't have so many boring days stuck where you can't do radio!
This is the schematic for the tuner, any comments welcome. On the left shows the evolution of this from an unbalanced pi network. It seems to be supported by the writings cited.
« Reply #23 on: August 22, 2008, 08:06:47 AM »
ifn you are going to use gear drives make sure you have the ability to slow down the rotation enough to make very fine adjustments, or you will forever be overshooting the exact match point and going back and forth.
you could make a swr autosense circuit and drive teh motors with that.
« Reply #24 on: August 24, 2008, 10:29:29 PM »
I'd prefer manual tuning, but the transmitters are at the end of the building and the best place for the feedthrough is on the side in the middle.
I'm not sure I'm smart enough to make an SWR autosense that would cover 1.8 to 30MHz. Also consider the size of the boatanchors that have been washing up on the shore lately is pretty scary.
The guy in the article put a multi-turn pot on his tuner, pretty smart.
Lucky the motors on hand are multi-gear reduction so they will stop quick, and will turn slowly with lower voltages. They are 24 volts. The biggest problem with using them is a 0.315" (8mm) shaft on the motors and a 0.375" shaft on the caps and coils. Since I am not very good at machinery, I won't be able to exactly align it all, and will try to use some long shafts and those flexible couplings to make up any small amount of misalignment.
Do you think I have enough capacitance? Looking at some charts, I should have twice as much, but the big air variables are not easy to get.
Page created in 0.092 seconds with 18 queries.
