May 16, 2024, 12:20:31 AM *
Author Topic: Look what followed me home!  (Read 18201 times)
AF9J
« Reply #25 on: July 08, 2008, 10:24:58 PM »
Hi Mike & Dave,
Thanks for your impressions on the Twoer Mike.  As I said earlier, I just hope that Ken, W9GA in Germantown (about 15 miles from me) doesn't fire up, or he'll blank out the TWoers receiver with his KW.  I also noticed in Steve's net list, that Ludington, MI (about 15 miles as the crow flies across Lake Michigan from me), also has a 2m AM net on Wednesday nights.
Dave, I tried Solder wick on the HP-23A power supply' s twistlodk cap tabs last year, and got fed up with trying to pull off the solder.  The builder of the supply put solder on by the ton.  It was late at night, and I was getting fed up with trying to remove the stuff. Hopefully the Twoer will not be slathered in solder on the quad cap's tabs.
Ellen - AF9J
kf6pqt
« Reply #26 on: July 09, 2008, 12:53:40 AM »
I'm curious to hear of the results of the solid-state class C amp used on AM experiment,  I've got the 100w PA section from a lowband (~6m) highway patrol Motorola Micor that I used with the funny Cherokee 6m FM ht long a ago. (a POS radio, imho, btw)
Jason kf6pqt
W6IEE, formerly KF6PQT
« Reply #27 on: July 09, 2008, 11:15:46 AM »
Jason kf6pqt
Hi Jason,
Check the Micor schematic to be sure they are not using a base-leak or a self biasing scheme on that class C amp.  Fixed bias is what you need - but it could be modified with a zener if so.
Another way to test it is to inject in an RF carrier and vary the level. Measure the base DC bias  (on the DC side of the choke, on the other side of the RF) to see if it stays fixed or varies. You want rock stable bias, cuz with linear drive to the base, under modulation the self bias would vary and cause unwanted distortion.
The Mot Micor is a beautifully built rig...almost like mil-spec. Back in the early 70's I was a Motorola tech and used to repair and maintain them.
