April 29, 2024, 02:32:59 AM *
Author Topic: Comparing rf output to audio input  (Read 2962 times)
« on: July 06, 2008, 05:17:44 PM »
Attached is a .jpg slide that is a copy of a pair of traces I recorded from my oscilloscope. [The scope allows me to save 10,000 points for each of its two inputs / traces on a floppy disk... in the format of an Excel spreadsheet. The spreadsheet, once transferred to my computer, allows me to plot a graph with both traces... plus I added a scaled/offset version of one of the traces]
Transmitter: 4-FET  Class E / Class H transmitter... 200 watts at carrier
Trace 1 (red): the output of my off-air monitor (i.e., the output of the "pickup" that came with my REA modulation monitor)
Trace 2 (green): the audio input to the Class H modulator (when I look at this in real time, I usually scale and offset the audio trace to sit on top of the off-air monitor trace... but the spreadsheet that the scope gave me as an output file did not include the scaling and the offset)
Trace 3 (blue): Same as trace 2, except scaled and offset to sit on top of trace 1.
Note that trace 1 (the envelope of the rf output of my transmitter) tracks nearly perfectly with trace 3 (the audio input to the Class H modulator)... except at points around 2500 on the horizontal scale... where the negative peak limiter in the Class H modulator keeps the rf envelope from following the audio to negative modulation levels greater than 95%.
The horizontal scale (points numbered 2 to 10001) corresponds to 4 milliseconds of total sweep time.
The digital scope stores each sample in a memory... so what is displayed is whatever the two channels had on them since the most recent trigger. In this case, I was triggering on an upward level crossing... with the level set at about 70% positive modulation.
The display on the scope (which is still there since I decided to make this posting about an hour ago) is much cleaner than the attached .jpg
Best regards
« Reply #1 on: July 06, 2008, 11:33:43 PM »
Very nice and accurate!
« Reply #2 on: July 08, 2008, 05:24:26 PM »
To illustrate how a combination of an A/D converter (in effect, a DC-coupled sound card) and an associated software application can be used to perform analyses of a modulator's / transmitter's behavior... including functions typically performed by a modulation monitor:
Attached, below, is another scope trace (i.e. saved from the digital scope to a floppy disk as an excel file, then transferred to my computer for plotting a graph, and then saved as a .jpg)
This trace is of the output of an off-air monitor (an envelope detector), while modulating my homebrew, 6 meter, 6146 plate modulated AM transmitter.
I don't show the corresponding audio input to the modulator... but it overlays on the output of the off-air monitor nearly perfectly.
The horizontal axis is 100 milliseconds long (10ms per division x 10 divisions)... and corresponds to the last segment that triggered my scope.
I added two red lines:  carrier level and 100% modulation level
You can see the positive peaks going above 100%
Again, although the above was done using a modern digital oscilloscope... all of the A/D conversion and sample storage is taking place at audio sampling rates
« Reply #3 on: July 18, 2008, 12:45:09 AM »
That's alot of high tech instruments there. I guess the big advantage is being able to capture the data and save it for comparison. Keep up the good examples of how this is done!
Page created in 0.032 seconds with 18 queries.
