May 05, 2024, 08:25:09 PM *
Author Topic: HYTRON TUBE HY31Z DUAL TRIODE  (Read 5148 times)
« on: June 14, 2008, 09:59:22 AM »
I'm looking for the specifications on an old tube as noted above. I looked at all the tube sites, nothing found. Maybe someone has the data in an old hand book. I have four of these and it looks like they could make a cool OB rig. Any help would be appreciated.
Thanks in advance,  Terry
W1EUJ
« Reply #1 on: June 14, 2008, 11:03:54 AM »
6.3 Fil 2.5 Amps
500 V Max. Plate Voltage
150 mA Max. Plate Current
30mA Max. Grid Current
30W Max. Plate Dissipation
Mu of 45, each triode
Cgf 5pF, per section
Cpf 1.9, per section
Cgp 5.5, per section
Class C Telegraph B+: 500, -45V grid, 150mA plate current, 25mA grid current.
2.5W grid drive, 56W output typical
Class C Phone B+ 400, -45V grid, 150mA plate current, 30mA grid current. 3.5W grid drive. 45W output typical
Class B Audio B+ 500, 0V grid, 150mA plate current, 1.8W grid drive, 7000Ohm load impedance, 51W output typical
From RADIO Handbook, Eighth Edition, 1941.
In general, those 30's - 40's RADIO Handbooks used alot of Hytron and H&K tubes in their designs. I'll send you my copy if you need.
David Goncalves
W1EUJ
« Reply #2 on: June 14, 2008, 01:42:30 PM »
Neat O Dave, What is the resting current on class B service? I don't need a copy, I'll just save this page.
Thanks again & 73
Terry
KE6DF
« Reply #3 on: June 14, 2008, 07:49:54 PM »
Here is some data:
http://www.nj7p.org/Tube4.php?tube=HY31Z
Attached is a page from an old handbook with some more info.
* HY31Z.pdf (47.22 KB - downloaded 200 times.)
KE6DF
« Reply #4 on: June 14, 2008, 08:14:55 PM »
This may not be of much use, but it's another result of some google archeology.
Here is a picture of a 1940's rig using an 828 final modulated by an HY31Z.
http://www.rigpix.com/mischam/subraco_75t.htm
W1EUJ
« Reply #5 on: June 17, 2008, 09:53:34 AM »
Sorry Terry, no additional info available.
