The 1500 is a different set up. I just want to know if I can stick a brade spoon in the lever slot and turn it. I never use my parking brake either but noticed it slipping last week on a hill. The 2500 has 2 shoes like the old drum brakes but this thing has a single shoe that is round.
That site is way too ya-hoo for me.
Yes. You should see a small star wheel thru the slot right next to the cable pull hook sticking out of the backing plate. Before you try adjusting those, make sure there's no slack in the cables with the parking brake released.(May need to adjust out the cable slack at the pedal first. I've had my fair share of these and personally, the best way to get it right the first time is to lift and support the rear on stands so you can spin the wheels easily. Just adjust the star out till you hear the slightest drag, then back it off a bit.
ON EDIT:
There was a recall regarding those loosening up BTW. Little bit 'o google and here it is. The reason they say manual trannies is b'cuz people with sticks tend to use the e-brake all the time, so it loosens up much faster. BUT, the hardware in the back is the same for an auto also. This one may not apply to you, but it's worth a look anyway.
2001 CHEVROLET SILVERADO -- On certain pickup trucks equipped with manual transmissions and built with either PBR parking brake systems or TRW parking brake systems, the parking brake friction linings may wear to an extent where the parking brake can become ineffective in immobilizing a parked vehicle.
If the parking brake does not hold, unintended vehicle movement could occur, which could result in a crash.
Dealers will install a low-force spring clip retainer for vehicles equipped with a PBR parking brake system. On vehicles equipped with the TRW parking brake system, dealers will install a redesigned parking brake cable assembly. The recall began on July 29, 2005. Owners may contact Chevrolet at 1-800-630-2438 or GMC at 1-866-996-9463. For detailed information & supporting documents, see the official NHTSA page concerning recall #05V161000 »
