May 03, 2024, 01:58:06 AM *
Author Topic: Art-13 Power Supply  (Read 2829 times)
W7SOE
« on: May 22, 2008, 12:51:46 PM »
I am in the "parts gathering" stage of building an ART-13 power supply.  With regards to the HV supply, I would like to provide up to 1500V, adjustable via variac.
Am I correct to think that I will need a 3000V CT transformer if I use a couple rectifier tubes (.6366Vp ?) and that I would need a 1500V non-CT transformer if I used a solid state bridge?
Rich
Rick K5IAR
« Reply #1 on: May 22, 2008, 04:30:25 PM »
Sounds right to me, Rich.  Don't forget to compensate for the voltage loss across the rectifiers, etc. if you go with the tubes.
Gud luck!  It should be a heck of a rig.
Rick/K5IAR
W7SOE
« Reply #2 on: May 22, 2008, 04:53:39 PM »
Thanks Rick.
Anyone have experience with Antek Toroidial transformers?
Rich
W7SOE
« Reply #3 on: May 23, 2008, 05:39:39 PM »
Another question.  If, for example, I need 400VDC and I have a 900V transformer with CT, can I use it with the CT grounded and two solid state diodes?  Basically the "tube" configuration" with the tubes replaced by diodes?  These would be very high voltage diodes I suppose....
I am looking for the three transformers I need (to produce 1500VDC, 400VDC, and 28VDC) and would like to know what my options are.
Rich
KE6DF
« Reply #4 on: May 23, 2008, 07:07:42 PM »
There is a thread here on this site about the 400 v supply.
http://amfone.net/Amforum/index.php?topic=9170.msg68037#msg68037
Dave
