OK, here's the setup. Dx-100, 1625 mod tubes, with the stock 1k grid resistors, (they're good) stock driver transformer... and thats it. Speech amp is removed still.
So, finally doing what I was instructed to do eons ago, I have measured the grid bias voltage, at the center tap of the driver transformer.
Resting, no modulation, as none is possible at the moment:
standby, phone: -39.5v
standby, cw: -39.5v
transmitting, phone -37.2v
transmitting, cw -37.4v
Then, I unsoldered the center tap, and put a meter in series... make that two meters, my usual $3 halbol flate DVM, and a tankerly Triplet model 630-NA... and I cannot detect any current flowing none.
Lemme know what you think of this...
Here's the 1625 plate voltage:
#1 #2 (at each plate cap, to ground)
standby
cw 2.06v 2.01v
ph 2.96v 2.94v
Transmitting
cw 795v 792v
ph 789v 789v
Then, as I re-read my instructions, I lastly checked the screen voltage, between the screens to ground... and it got exciting.
Screen voltage:
Standby:
cw: nil phone 1 volt
transmitting
cw 4.17v Phone: went up to 240, and then started dropping slowly. At about 236v, something arced, and I shut off the plate voltage.
Looking at it do this again ( still didn't see where the arc came from) I noticed that my aft 1625 has the cool blue glow, and the plate is starting to heat up good. Short?
I detected a tiny bit of blue on the front 1625, and I'm pretty sure its not a reflection from the back one. Is it still good, or too gassy as well?
Hmm, will be digging out the box of 1625's.
Here's the instructions I was going by:
WA1GFZ:
Measure the bias voltage at the CT of the driver transformer. It should be around -36 volts and the resting current around 50 ma. report your reading and get plenty of advice. Also check the screen voltage and report. remove the driver tube before you read the numbers to make sure nothing is driving the modulators.
Thanks and 73,
Jason kf6pqt
