May 16, 2024, 07:48:11 PM *
Author Topic: DX-60 help  (Read 2972 times)
N8IE
Bullies need love too, hug me or I'll punch you!
« on: May 14, 2008, 08:11:26 AM »
Hello all,
I picked up a couple of DX-60's for parts and found one to be in pretty good working order and worthy or restoring. It's a DX-60A model, are there any major circuit differences between the A and B models?
I know the later DX-60 production was different, but can I use the DX-60B manual as a guide for the DX-60A?
Also, I'm going to move the HV off the function switch and onto a relay. I drew up the changes (based on a mod by WC3K) and would appreciate it if someone could double check my schematic.
http://n8ie.com/documents\DX60.zip
Thanks es 73
Dan, N8IE
For just $1 a month you can save a Ham from SSB.
Please give to AMfone today, I did!
Remember, Hams don't let Ham's run SSB...
Dan, N8IE
« Reply #1 on: May 14, 2008, 09:02:11 AM »
Hi Dan ...  good looking schematic diagram ...a little more work would make this step start and slow WAY down relay contact erosion .....  use a DC coil relay (or some have reported sucessfully using a 120 Vac coil on 24 Vdc) with a charge up time constant of 1 or 2 seconds ... standard handbook stuff or ask if you need mo' info...73...John
W4EWH
« Reply #2 on: May 14, 2008, 10:21:34 AM »
That's a great drawing! Please tell us what software you used to create it, es TIA..
73, Bill W1AC
P.S. You don't need to zip your images: jpg's are already compressed. HTH.
N8IE
« Reply #3 on: May 14, 2008, 12:17:59 PM »
73, Bill W1AC
Thanks Bill,
Actually that was a scan of the schematic then I free handed it with MS Paint.
I've done that for years so it's second nature to me. :-)
Thanks for the tip on images, I'll remember that.
Dan, N8IE
Dan, N8IE
N8IE
« Reply #4 on: May 14, 2008, 12:20:02 PM »
Thanks John.
I do know the relay uses a 12 VDC coil so there I'm good.
I'll look at the delay and see what I find.
Dan, N8IE
Dan, N8IE
