Hi Tom,
I prefer to restore, rebuild, or re-engineer. With everything from BC transmitters that worked at one time to the worst of what some folks have named "Hammy Hambone" jobs, I get enough variety. I build from scratch when necessary or when what I want is not available or is unaffordable. I am sure my doings are relatively common, since I don't have alot of time to physically craft truly fine instruments.
Here's what is going on now, divided into sections:
What Radio gear is basically in running condition now is:
*USA and Military:
RCA BTA-250 that needs moved to 160M
Sunair GSB-900DX HF XCVR
National NCL2000 amplifier
SDP 1000L RF Power Amplifier
two GRC-106A HF tranceivers (one CARC 8-) )
Racal RA-6217 receiver
two Logimetrics 925 signal generators covering 50KHz to 80MHZ (for VFOs)
ITT FA-8190 UHF AM aircraft tranceiver (military band)
ITT FA-8191 VHF AM aircraft tranceiver (civil band)
two Rycom R1307 receivers
RT524
RT246
two PRC-77
PRC-25
two Racal TRA-967
(also various audio items, I like the sound of vacuum tube gear)
*Riceboxes:
Kenwood TS-430S (with FM, narrow CW, and wide AM filters)
two Icom IC706
Alinco DX-70
Alinco DR-135
Alinco DR-435
Things that I am working on now -need fixed or finished up:
Link 250-UFS 250 watt 6M base station
"Col. Tucker" KW AM rig covering 80-10M
two R-390's
two R-220's
Harris RF-130 (needs about 200 tantalum caps replaced..)
also adding LSB to one of the GRC-106A's
Things that are just lying around forlornly:
six T-282 AM transmitters 200-400MHz (no power MD-141 supplies/modulators)
--note - these have been known to be able to do 100W ATV as amplifiers
three MD-129 PSU/modulators (for the T-217 'autotune', probably will work with the T-262's)
FM BC exciter, RCA? 10 watts -needs help. (heck it needs a home)
three Collins 618S-1 transceivers
three 1500W CCS RF generators on 13.5 MHz using 3-1000Z's
I have built a scant few from the ground up. The major things I have built from nothing but parts and more or less my own designs were:
3-1000Z SSB-rated linear amp
100W PEP AM-durable linear with two 6146's
50-950MHz spectrum monitor
2000V 260mA power supply
400V 500mA power supply
800V regulated screen supply for 4CX5000
200W 400Hz inverters running from 10-15VDC (to power a Collins 618S-1 servo/bias circuit)
MOPA CW rig with a 45 (before I was licensed -it tore up the TV pretty good)
100W audio amp using 8 6L6G's in push pull parrrrallel
"demonstration platform" version of a microwave directed energy weapon
--The only things of these still around today are the 400Hz inverters, 6146 amp, and the spectrum monitor.
I've done alot more of taking something that exists and making it do what I want or what others want. One of those is a class-A series modulator and power supply for a low power AM transmitter (807, 5 watts carrier). It was made from one of those electronically regulated tube type HV power supplies.
I am between antennas at this time, except for a 40FT piece of wire. Soon, I keep telling myself. Pictures of much of this stuff can be seen at
www.bunkerofdoom.combest regards,
Patrick
