May 06, 2024, 02:21:44 AM *
Author Topic: Thermador CS-2160, again  (Read 3366 times)
Barrie
« on: April 03, 2008, 02:48:54 PM »
Several months ago I asked if anyone knew the specs on a Thermador CS-2160 modulation transformer, with no luck.
After some cleaning, I have more information from the specification tag.
Primary is 6700 ohms
Secondary is 4500, 5000 or 5500 ohms
Max operating level is +47 db
Weight is 20 lbs
I suspect that the +47 db may have something to do with the modulation capability, but I don't have a clue.
Anyone less clueless?
73, Barrie, W7ALW
W2XR
« Reply #1 on: April 03, 2008, 04:05:23 PM »
Barrie,
The 47 dB specification is probably the maximum audio operating level above 0 dBm (1 milliwatt).
This translates to 50 watts of audio power.
This being the case, this mod xfmr is probably designed to modulate a 100 watt RF input final amplifier stage to 100%.
Hope this helps!
Bruce
« Reply #2 on: April 03, 2008, 04:58:54 PM »
In that case it would be specified as 47dBm.  I would say that 47 dB is more likely to mean 47 dB above 0 dB @ 6 milliwatts reference.
Older equipment used 6 mw as the reference level, but nowadays almost everything is referenced to dBm.  I'm  not sure exactly when the change was made.
W2XR
« Reply #3 on: April 03, 2008, 05:12:17 PM »
Don,
Obviously, that would make a big difference in the power handling capability of this transformer.
If what you are suggesting is correct, that would mean this transformer is rated at 300 watts of audio, and not 50 watts as I am suggesting.
The weight of this transformer is given as 20 lbs. That sounds rather light for a transformer that is rated at 300 watts of audio, even if the frequency response at the low-end is strictly communications-grade. The audio response was not defined by Barrie.
Bruce
« Reply #4 on: April 03, 2008, 05:36:24 PM »
20 lbs seems a bit low for a 300 watt transformer, and a bit high for a 50 watter, but usually 0 dB reference is written as dBm.
Somewhere around here I have one of the smaller hermetically sealed BC-610 mod transformers, rated for about 250 watts of audio, and I doubt if it even weighs 20  lbs.  But I have a 125 watt multi-match that probably weighs 15 lbs.
It could be a "communications grade" audio unit, and achieves lightness in weight by limiting the low frequency response.  One example of this is the ART-13 modulation transformer.
