Not much to this thing (1 tube + rectifier) so you won't find much or any troubleshooting info. The assembly manual does give wiring details and pictorials Under the heading "In Case of Trouble", they say: check the wiring, check tubes, check all parts and resistors, trace out all the wiring. Still problems, call the factory.
Check the tube. Check to be sure the cold side of all the coils go to ground. Check R1 and C1.
