Tetrodes and pentodes are good for modulated stages, but they need some screen modulation along with the plate modulation to force some variation in plate current. Without any modulation on the screen, plate current will not vary much with plate voltage until the instantaneous plate voltage swings pretty low on the modulated waveform. This results in badly distorted modulation.
Most simple designs for low and medium power tetrode and pentode modulated stages just connect a screen dropping resistor from modulated B+ to the screen(s). But this
overmodulates the screens, and that causes distortion as well. It is better to connect this resistor to unmodulated B+, although there is an even better way to do it (see below).
The screens want about 50% to 60% of the modulation compared to the plates. The varying plate voltage will cause variations in screen current, and this can be used to self-modulate the screens if a resistance, or inductance of high impedance, is in series with the screen. This self-modulation is a little bit light, so some additional modulation should be applied, as shown in Deano's article (link below). The simplest way to add decent screen modulation is shown in my own article (link below), which works, but is not quite as good as Deano's solution.
This is the best way to do it:
Class C Optimization for Ultra Low Distortion
Dean, WA1KNX
http://www.amfone.net/AMPX/71.htmAnd this is a simpler way - not quite as good, but you'll definitely get the idea:
THE SELF-MODULATED SCREEN GRID
Bacon, WA3WDR
http://www.amfone.net/AMPX/98.htm - Bacon, WA3WDR
