May 07, 2024, 04:53:28 PM *
Author Topic: Mains power lamp  (Read 2383 times)
David, K3TUE
Per-spiring AM'er
« on: February 06, 2008, 02:26:09 PM »
In many tube-type circuits I see it common to use an incandescent lamp run from secondary side filament power to indicate mains power on.
In the power supplies I am working on I do not have this luxury.  So I was wondering if using a simple and cheap neon lamp on the primary side is ok instead, or are they somehow problematic?  I was wondering if they tend to induce unwanted noise into the supply that will end up in my signal.
David, K3TUE
« Reply #1 on: February 06, 2008, 02:40:50 PM »
Neon bulbs last for ever I prefer them on the primary.
« Reply #2 on: February 07, 2008, 08:15:05 AM »
dont forget the 100k current limiting resistor  Grin Grin
« Reply #3 on: February 07, 2008, 11:35:30 AM »
And they require about 67 volts or thereabouts to fire, so they wouldn't work off an ordinary filament winding anyway.
