jeez. When it was 60 last week I kept saying, you know you gotta get your grounds in the house so you can connect everything together....
well, I'm going out anyway. I got 2 pair sweats hat and gloves and 2 pairs of sox on. (cold is a trigger for seizures) and if you find me face down in the snow I didn't make it.
PS - last night the old bridge rectifier board got stripped and cleaned. One of the diodes burned up at some point there too in the past and left a zorch mark. Ready to install new diodes and teflon HV wire and be reconnected.
Then we wire up the new lytic stack. Ya know, I got enough room to put in some good oil filled caps in there. Mount em on standoffs. I wonder......hmmmmmm
then the new rg 400 silver teflon coax input - outpoot goes in with N connectors both sides. 2000 watts pep is a lot of watts.
I'll be around - I gotta a lot of things to do.
update: assuming Yaesu #1 is really fixed, I should be on tonight. Putting things back together now. Got a wifey honeydo to do then I'm free to operate!
