May 04, 2024, 12:14:28 PM *
Author Topic: Two tone generator?  (Read 5419 times)
K7EK
ASA Lives!
« on: January 15, 2008, 11:34:28 PM »
I need a two tone generator for adjustment of transmitters. I prefer something cheap and
simple, and possibly something using a computer sound card. I'm open for suggestions.
Your ideas? Thanks in advance....
Best regards,
Gary E. Kohtala - K7EK
« Reply #1 on: January 15, 2008, 11:39:56 PM »
For a sound card there are doubtless a great number of "signal generator" programs, freeware, that will generate more than one frequency. Should be sufficient and then some.
Google?
           _-_-WBear2GCR
W0GSQ
« Reply #2 on: January 16, 2008, 06:04:28 AM »
I've used Comtekk with good results, it's a freebee.
« Reply #3 on: January 16, 2008, 09:06:07 AM »
If memory serves me correctly, the Heathkit SB-610 has a two-tone generator built in. If you have one of those you could use it.
David, K3TUE
Per-spiring AM'er
« Reply #4 on: January 16, 2008, 01:23:38 PM »
I'm fond of Elecraft's Mini-Module Kits.
http://www.elecraft.com/mini_module_kits/mini_modules.htm#2tgen
2T-gen  2-Tone Test Generator (700, 1900 Hz)   $59.00
  Specifications:
    * AF Output Level 200 mV max, adjustable, female RCA connector
    * Frequency 700 Hz and 1900 Hz
    * Harmonic Distortion -55 dB typical
    * Current Drain About 3ma. from on-board 9-V battery
    * Size PC board: 3.5"L x 2.4"W; 1.0"H
David, K3TUE
Ian VK3KRI
« Reply #5 on: January 17, 2008, 06:43:11 AM »
How about a DTMF keypad?
« Reply #6 on: January 17, 2008, 11:47:16 AM »
Coincidentally, I found one in my junk collection last night while looking for a microphone connector.  It is a  small tube type, built from an article in a 1955 QST.  I hooked it up and it worked perfectly.
I don't know where it came from or who built it, and didn't even remember having it, but I plan to use it as a tone generator for the T/R control function on my CQ-bot project.
« Reply #7 on: January 17, 2008, 04:12:09 PM »
Just blow harp like Buddly.
« Reply #8 on: January 19, 2008, 09:58:00 AM »
The two tone generator I use for transmitter testing is TCube by Alberto I2PHD. Works very well...as does everything by Alberto...
http://www.weaksignals.com/
« Reply #9 on: January 19, 2008, 12:03:47 PM »
Jay
Works like a charm!
I've always wanted to have a two-tone generator ... and this one is fun and simple to use.
Thanks!
« Reply #10 on: January 19, 2008, 08:43:24 PM »
  "  Just blow harp like Buddly.   "
I just didn't know.....
Page created in 0.076 seconds with 18 queries.
