May 18, 2024, 04:38:46 AM *
Author Topic: Electrolytic Capacitor  (Read 5085 times)
« on: January 13, 2008, 04:54:38 PM »
Is there a way to determine the polarity of an electrolytic capacitor besides looking at its markings?  I bought some electrolytics with questionable markings.  The negative lead (which I think is the negative lead) is marked with a dashed line.  The line that I'm assuming is the negative side is more like a line with very small spaces than a line with larger spaces between the lines making it look like they're minus signs.  The rivet is also painted like many electrolytics which typically is the negative side.  An ohmmeter doesn't yield anything concrete so I'm not sure how to determine the right polarity.
N9NEO
« Reply #1 on: January 13, 2008, 06:30:39 PM »
Hi Bob,
you might be able to put a supply on it and watch the current as you bring it up.  I think when connected the wrong way you will probably see greater leakage current.
PS. Have a great 08.  Wife and I are thinking of renting a place on Lake Hayward for the summer.
Carl WA1KPD
« Reply #2 on: January 13, 2008, 06:38:57 PM »
Can you post a pic?
« Reply #3 on: January 13, 2008, 07:04:12 PM »
Drop a 6 or 9 volt battery across it (use a series resistor if you want)...
after 3 or 4 seconds, remover the batt, and put your voltmeter on the terminals... see which is - or +
« Reply #4 on: January 13, 2008, 08:12:19 PM »
I would put a resistor in series with the power supply to limit current. Send me a picture if you can and I will see if I can tell.
a reversed cap will leak and become a resistor. As the cap heats up pressure builds until the seal pops.
« Reply #5 on: January 18, 2008, 05:35:26 PM »
I'll post something this weekend.
« Reply #6 on: January 18, 2008, 07:03:38 PM »
Bob, what do you need?
« Reply #7 on: January 19, 2008, 10:43:30 AM »
Here are the caps in question.  Can I assume that line is the negative side?
VE7 Kilohertz
« Reply #8 on: January 19, 2008, 10:51:53 AM »
Hi Bob,
I would say you are correct, the black post, with ----- would be negative.
Cheers
Paul
Women. Ya can't live with them......pass the beer nuts!
« Reply #9 on: January 19, 2008, 11:09:06 AM »
Agreed.
« Reply #10 on: January 19, 2008, 11:56:19 AM »
OK, that settles that.  Thanks.
