h-ok John. The amp is starting to look pretty sweet. I used the stupid glue on the cracked ceramic with the finest chinese made runny shit you can buy. Worked FB OM.
The amp project has turned the corner. There is now more stuff repaired than there is broken or needing changed due to ravages of time. This thing will be very dependable. I also might get around to putting in the RGS-400 coax input and outputs today. The silver plated connectors had massive amounts of tarnish and pitting due to sitting up against steel for 40 years. The so-239 "out" jack was literally glued to the chassis by black crudstuff so thick I had to Dremel it off after the nut and lockwasher wuz removed. Tarn-X couldn't touch it. The T/R switch is repaired and back in. The new 3 wire ac line cord and fuse holder are in.
Money is tight right now so I am fixing everything else in the beast before I go back to the bandswitch. I want to silver plate the tank circuit and switch before I put it back in, and I'm gonna use one of those plug and plate systems from
http://www.caswellplating.com/kits/plugnplate.htm and do it myself. I dont
have to, but for a 40 buck investment I need never worry about such things again and I can repair other gear with it as needed.
