December 02, 2025, 07:12:35 PM *
Author Topic: Grounded Grid Input Impedance  (Read 4166 times)
W1QWT
« on: November 27, 2007, 12:00:17 PM »
Hi
I am trying to add 160 meters to my SB-200. Need to make a L network impedance transformation circuit.
I know one side will be 50 ohms but how does one either find or compute the side that couples into the filament?
In other words the impedance that the output of the L network will be looking into.
Also while my nickle is running I have a stupid question. Everyone knows you tune the output for a dip and then load to the antenna. My question is just what is going on in the circuit that causes the plate current to dip?
Is it the point where the reactance power is canceled out and only resistive power is left?
In this case I can see the plate current going down cause your getting rid of the useless reactive current.
Maybe I am all wet but that is the only explanation I could come up with. OFcourse my boss helped a little.
Regards
Q, W1QWT
Regards, Q, W1QWT
« Reply #1 on: November 27, 2007, 04:03:22 PM »
Double the cap and inductor values from 80 meters then tune the inductor for best match
« Reply #2 on: November 27, 2007, 05:27:00 PM »
For a linear amplifier such as the SB-200, why even diddle with dip and load. Just adjust for maximum forward power in the line to the antenna. Of course this assumes the antenna is cut reasonably close to the frequency of operation and/or you have an antenna tuner between and antenna and linear to minimize any reactance. I've used an SB-200 for about 20 years (15 on AM) and just tune for maximum output smoke. Still uses the same 572B's that were installed in it in 1969.
W1QWT
« Reply #3 on: November 28, 2007, 08:04:53 AM »
Well thats true, in the past I found that to work as long as the max tube currents were adhered to.
But I want to understand the exact principles behind "dipping the plate". My understanding is that the PI network
is really an impedance transfer device to match the tubes 5K output impedance to a 50 ohm antenna system.
So the explanation my boss gave me about tuning out reactive current hence the dip seems the most plausible so far.
Also I would like to know how to measure the input impedance so I can try different approaches with the 160 meter L circuit and not just double values. Does a tube spec sheet give this info?
I suppose I could measure the cathode RF voltage and current and calculate.
Regards
Q, W1QWT
Regards, Q, W1QWT
« Reply #4 on: November 28, 2007, 10:46:06 AM »
A Pi network is back to back L's.
My assumption has always been that the dip happens because you pull less current at resonance than you do on either side.  When your running out of resonance, you're still driving the tube to get X amount out of it (usually grid current measured here).  Transistors are the same way.  Don't tune X out of the broadband xformer, and you end up with blown xsisters...  Either from much too much I being pulled, or too much V (reactance can cause wild voltage excursions).
Pretty much sounds like your answer, once it's down on paper, too.
Input impedance is usually found either on the internet, by doing the math, or data sheets.  If you have an MFJ antenna analyzer, you can tune the amp up for max output, then connect the mfj to the ANT jack, and put a pot on the tubes (all voltages off here, unplugged, relay energized (manually, if you ask me).  Tune the pot for 50 ohms indicated on the MFJ.  Remove pot, measure value.  That's your loaded value of the input impedance for X amount of tubes.  Simple shyt, really.
Regards
Q, W1QWT
Page created in 0.051 seconds with 17 queries.
