Is that with the RF drive still on?
Roger. The RF drive produces the 100ma grid current if the HV is not on.
>It is best to drive a modulated stage (especially a triode) with a soft source like a tetrode or pentode, to regulate the grid current.
Not sure what you mean but it is driven by an 807.
>Of course, normally you would turn the drive off when you drop the plate voltage. I assume that you left it on while testing.
Right but also, it is my MO to adjust the grid drive before turning on the HV. With my 8000, the grid current does not change at all when I turn on the HV.
>A grid draws more current with low plate voltage because the plate isn't sucking on the emitted electrons as hard, so they go to the grid instead, which means more grid current.
I understand that but a factor of two?
js
