December 02, 2025, 10:29:52 PM *
Author Topic: Diode strings in secondary of mod trans  (Read 3236 times)
w5dud
« on: August 06, 2007, 03:02:03 PM »
Hello picked up a Globe King that has been modified and discovered that in the modulation transformer secondary ,that both leads have a string of diodes in them , is this to take the place of the resistor that went between the secondary leads, thanks W5DUD
2ZE
« Reply #1 on: August 06, 2007, 03:31:49 PM »
Probably zener diode clipping arrangement. Can confirm by reading the numbers off the diodes, and cross referencing them. There should be a long string of zener's connected anode side to the modulated B+, and a shorter string of silicon diodes connected anode side to the unmodulated B+, and the two strings meeting cathode to cathode somewhere.
« Reply #2 on: August 06, 2007, 03:33:05 PM »
maybe this?
http://www.amwindow.org/tech/htm/zenlimd.htm
Home of GORT.
w5dud
« Reply #3 on: August 06, 2007, 05:47:56 PM »
Thanks for the info , after looking at it , that is what has been done, Thanks W5DUD
« Reply #4 on: August 06, 2007, 08:13:28 PM »
You might want to try cutting them out and listening to the TX audio. I bet it sounds better. I HAD a DX100 and it didn't like that diode limiting thing on the secondary. You can run some processed station audio into the input of the Tx or just use a good ole D-104 and that should give you plenty of audio.
The iron in those Globe Kings wasn't the best. Consumer quality equipment. Not meant for 24/7 operation or lotta overloads.
Page created in 0.127 seconds with 18 queries.
