I question,--Is that that a grid current meter near the plate current meter?
If so I think, I would move that grid meter under the chassis to prevent any coupling between the grid and plate current meter.
Never occurred to me to put it under. In fact, it never occurred to me that there would be a coupling problem with meters with RF chokes and bypassing .
>Also, is that variable cap in front of the oscillator, for grid tuning?--I would also move that under tht chassis to minimize osc-final coupling.
You're gonna love this... it's the VFO tuning. The grid tuning is underneath. Both the VFO and grid coils are toroids so the coupling would be minimum between them. The only thing on top is the cap and it's grounded and the tube is metal.
I suppose the whole VFO should be in a box but this is sort of my Mr Wizzard Science project and it's informative to see the results of not following the rules and fixing things as needed.
The final self-oscillation seems to have been fixed but now I have a self oscillation in the VFO. That seems like an oxymoron but it's a very unusual one. It is a ticking at about a 500 ms rate when I unkey. I have the oscillator on all the time and key the grid bias for a nice clean, chirpless key but the ticking between is nutty. I fixed it with a 9V battery as a fixed bias supply. Don't ask me how this solved anything but it did. Now I need to find out what the real cause it and fix it right.
I also added a fixed bias supply for the 807 to cut it off when the key is up. Works real nice. Used a backward fil trans on an unused fil winding on the power trans. Same trick I used on the 8000.
Lot's more problems to resolve yet but it wouldn't much fun if it worked the first time I plugged it in. Things that do that are called rice boxes and are boring as hell.
>Just a couple of thoughts, that might help.
Thanks. Never too many thoughts,
js
