May 05, 2024, 12:44:16 PM *
Author Topic: AL-80A grid current meter problem  (Read 5736 times)
ka2zni
« on: April 25, 2007, 11:06:19 AM »
I should be more knowledgable about this stuff but, The grid current meter quit workin' all at once, the illumination bulbs on that meter are a tad bit brighter now, wondering if there was some simple fix to this or what would I need to check it? I thought maybe a multimeter and check across the terminals for current, other than that I do not have an idea and was wondering if anyone else has run into this problem..
« Reply #1 on: April 25, 2007, 02:02:13 PM »
If I remember, the grid current meter is also the plate current meter. You can download the scheezo from MFJ. Looks like a PC board involved to take the readings and drive the meters.
http://www.ameritron.com/man/pdf/AL-80B.pdf
Sorry I can't help you more.
ka2zni
« Reply #2 on: April 25, 2007, 06:14:20 PM »
Thanks Fred.. Will give that a whirl..
« Reply #3 on: April 25, 2007, 08:14:42 PM »
Just a word of caution. The AL-80 version and AL-80A "early version" were made by Prime. The AL-80A MFJ later version had somewhat different circuitry than the "early" version made by Prime. Note: prior to Prime, the AL-80 was first made by Amp Supply.
ka2zni
« Reply #4 on: April 26, 2007, 01:38:03 PM »
Thanks pete.. Yup lucky me... Model #27 so I am sure it is a prime edition... And no luck w/ the fix so will have to find someone that can work on these a little more comforatable than me, sometimes if you see the same trend over and over w/ same part it's an easy fix, and probably so for the right guy, but 'ole model #27 is going out to be fixed I think.. thanks for the input guys.
« Reply #5 on: April 26, 2007, 02:13:31 PM »
My good deed for the day, see attached meter board for Prime AL-80A.
