The VFO in my GPT-750 has an intermittent in the tuning cap - conveniently right at 3700-3750 KHz- plus, it's about 60 KC low at the high end of its range. I tried taking it apart and the damn thing is like a matrushka doll - layer upon layer of shielding, insulation (asbestos
), heater elements, repeated - then finally a cast aluminum box with no way in from the top.
Apparently I have to go in from the back, and this will require removing the whole assembly from the transmitter - disconnecting about 25 wires, removing a bunch of screws, and several knobs. Before I go thru this I wanna make sure that's the right way and I'm not missing something.
Anyone had one of these bad boys apart?
