With hard-drive space becoming much less expensive, and large drives now the rule rather than the exception (I'm running a 500G drive here in the iMac), it just makes sense to copy the complete collection to the HD rather than keep switching discs.
So to that end I've been playing around this weekend with the Mac "Preview" tool and found a slick way to be able to sort, view and read the QST collection.
The simple way to go about this follows:
1) Create a folder on the HD, let's call it QST.
2) Insert a QST CDROM into the drive, and copy all the folders from the CDROM, they will be labeled by the last two digits of the year, say "17" for "1917", into the QST folder. Only copy the folders, not the extra files found on the first disc of each set as those additional files are for the "Aview" program which we do not need. Repeat as needed for the remaining discs, it takes about 5 minutes per disc on my 2.33 GHz iMac.
3) Now open the QST folder and select the year you wish to view. Inside the year will be another set of folders, labeled 1-12, for each of the months. Open the month you wish to view.
4) With the month now open, select all of the files inside the folder, they are labeled with the following nomenclature: year, month and page. For example 1512009.tif is really 1915, December, page 9.
5) With all the files selected, now right click and choose "Preview" on the menu bar. Once Preview opens you will now have the first file on the screen in front of you, and the remaining files will be listed in a column on the right side of the window.
6) To read the open first page, you can select Zoom In or Zoom Out to resize as needed. Then just use the arrow key to scroll down and see the succeeding pages, it is like reading a book!
7) If you want to really be lazy, and do this handsfree, you can select "Slideshow" and have the Mac turn the pages for you!
One more trick, and this only works if you are a ARRL member.
You can search the QST index for year, month, topic by using
http://www.arrl.org/members-only/qqnsearch.htmlEnjoy!
