March 09, 2026, 01:36:57 AM *
Author Topic: DX-100 audio  (Read 4436 times)
« on: December 14, 2005, 07:21:16 PM »
Welp, it looks like the driver transformer in the DX-100 crapped out. I checked my parts rig and it has a nice little void where the transformer was. What I would like to know is I have a Thordarson 20A18 interstage transformer designed for a single end driving push pull grids. Pri is 10Kohms/Sec 90Kohms with a 1:3 ratio. Would this transformer work in lieu of the OEM that bit the dust? The only thing I can garner about it is that it is a 2:1 Pri-1/2Sec and that is what comes off of the schematic. No other data such as its impedances are available. Many thanks for any help.
WA5VGO
« Reply #1 on: December 14, 2005, 09:52:02 PM »
I was under the impression that the DX-100 drove the 1625's into grid current. If this is the case, what you really need is a driver transformer(step down), rather than an interstage(step up) transformer.
Darrell, WA5VGO
« Reply #2 on: December 15, 2005, 06:37:39 PM »
Thanks, Mark. I forget that Peter Dahl's listing can be used as a resource too. I just found a Merit A-2921 that has a 1.7:1 Pri-1/2 Sec. It is listed as a driver transformer without any impedances. I wonder if this will be close enough without much degradation in the audio.
WA5VGO
« Reply #3 on: December 15, 2005, 08:22:05 PM »
Assuming that the primary current rating is adequate, it should be okay.
Darrell, WA5VGO
« Reply #4 on: December 15, 2005, 09:20:47 PM »
The primary is listed at 35mA. That should give me some headroom. TNX
