This is great I have been looking for a schematic like this for a while.
Stupid question.....The neutralizing plate on the bias circuit is new to me though it does make sense. Is as the schematic suggests one plate on one tube all that is required ?? Or am I naturally supposed to assume that both tubes get the same treatment ?
Yes, you have it correct - just one tube gets the treatment.
Since the two tubes are in parallel and in the same phase, a sampling from one plate off one of the tubes is all you need to pass some RF to the feedback circuit.
You can experiment with the size of the plate and the distance from the tube so that the adjustment capacitor tunes in the middle of its range. When doing a "cold" neutralization, you will see the feedthru signal null out quite well when everything is working right, indicating full neutralization and cancellation of the tube's undesirable feedthru capacitance.
