December 11, 2025, 01:35:19 AM *
Author Topic: Viking II restoration  (Read 9450 times)
xe1yzy
« on: August 16, 2006, 11:39:53 AM »
Hello to all
Im start to restore a Viking II & VFO122, I planning change all electrolitics, black beautis, and paper  caps, any other idea for " a must to" in this rig?
Regards !
TVI WHAT TVI?
« Reply #1 on: August 16, 2006, 12:13:53 PM »
http://www.amwindow.org/tech/htm/viking2.htm
Make sure all the frequency restricting caps are taken out of the entire modulator.
« Reply #2 on: August 16, 2006, 02:17:25 PM »
that circuit works even better if you use a 12AU7 with both sections in parallel instead of the 6C4. That has become my standard speech amp / driver circuit for all 100w table top boat anchor tx's.
(That is also basically the stock driver in a ranger.)
« Reply #3 on: August 16, 2006, 02:18:47 PM »
Hey, Buddly,
                   Where ya been hidin?? Havent heard you on for a Looonnnngggg time!!
xe1yzy
« Reply #4 on: August 16, 2006, 10:12:06 PM »
Thanks a lot guys...
Digging in the junkbox I found a Thordarson Interestage transformer, the ratio is 1-4, Type, T45901... Roll Eyes, I guess is for use with 6C5, what about a smoke test with this?...
TVI WHAT TVI?
« Reply #5 on: August 17, 2006, 08:04:53 AM »
I guess it depends on how you are running the modders. If you are running AB1 you may be ok. If you run them AB2 and they need a little grid current, the 1:4 may swamp out a single 6C4 driver. If you have it, try it and see how it works.
Antique enlectronic supply has a nice universal driver replacement that works fine. You can play with the taps and make it do whatever you want it to do. and they're relatively cheap. It is a Hammond unit, and I believe it is around $10 or $12.
xe1yzy
« Reply #6 on: August 18, 2006, 05:45:24 PM »
Ok, many thanks, well this rig needs a complet overhauling,  its a good idea check all the parts needed and yes buy a hammond transformer, after all the fun ends as soon as we put the rig back in the air isn't?, no to many Amers here in Mexico  Sad, but I enjoy a lot this rigs in CW anyways, Thanks Slab Bacon!
TVI WHAT TVI?
Page created in 0.048 seconds with 18 queries.
