Got this in the mail from Tony this morning:
SoftRock v6.0 orders now being accepted
My initial testing with the new SoftRock v6.0 is far enough along to
order production boards and kit parts.
The v6.0 SoftRock is a single board receiver kit that provides for
up to two band coverage without changing oscillator frequency or BPF
components. The board size is 1.5 inches by 1.9 inches and a built
unit has a height of about 0.6 inches. Band changing is by moving a
jumper plug on a three-pin header to give a divide by four or divide
by eight clock to the QSD circuit. A two-pin header on the board
provides for QSD mute if the two pins are open circuited. This
should help make the SoftRock more useable with a separate
transmitter.
Here are the two kit options that are being offered at this time.
40m/80m kit option
40m/80m two-band kit at $14 US/Canada and $15 for DX will tune the
following ranges:
40m with a soundcard that samples at 48 kHz - 7.032 to 7.08 MHz
40m with a soundcard that samples at 96 kHz - 7.008 to 7.106 MHz
80m with a soundcard that samples at 48 kHz - 3.504 to 3.552 MHz
80m with a soundcard that samples at 96 kHz - 3.48 to 3.576 MHz
160m kit option with selective 160m BPF
160m single band kit at $14 US/Canada and $15 for DX will tune the
following ranges:
160m with a soundcard that samples at 48 kHz - 1.819 to 1.867 MHz
160m with a soundcard that samples at 96 kHz - 1.795 to 1.891 MHz
Other band coverage will be offered after additional testing.
The audio cable has become a sourcing problem since the supply of
cables I was using with the v5.0 kits is no longer available in
distribution. Kit builders can get suitable cables from local
consumer electronic stores at a reasonable price.
Orders will be accepted starting today by PayPal to user name
raparks@ctcisp.com or by mailing a check or money order to me at:
Tony Parks
1344 E 750 N
Springport, IN 47386
I will get a picture posted in the files area in a couple days.
Thanks for your interest the SoftRock projects.
Tony KB9YIG
