April 07, 2026, 09:02:12 AM *
Author Topic: plate HV detector for tetrode / pentode power tubes  (Read 5420 times)
« on: September 06, 2016, 01:28:55 PM »
It is a pitiful thing to lose an expensive power tetrode by applying screen voltage BEFORE the plate voltage is there .... here is an idea for using a old technology tube (6BK4) as a HV detector (to 27kV)
                        -------------|------------------- B+
            6BK4                  - - - ----|
                                             \          /------------relay coil----- +lv
                                 2k         \<----|    npn
                                          gnd       gnd
well it just doesnt get too much simpler than this .... nothing fancy for the 6BK4 fil ...6.3v @ .2A near ground... just adjust the pot for desired minimum acceptable HV and use relay contacts to switch on the screen voltage
n.b. (7 sept)  of course you could just use a resistor(s) instead of the tube but would have a more limited detection range .... look at the tube manual curves .... also a differential amplifier would give a sharper go/no go decision
MikeKE0ZUinkcmo
« Reply #1 on: September 08, 2016, 12:05:29 AM »
Better yet, detect the screen grid current.
G3SEK sells a board and kit to do just that, however it is quite elaborate.   I took the essence of his design and installed into my NCL 2000 Linear amp.
This pic shows the detector, and you simply test with a LV power supply to determine resistor value needed for the Opto-coupler to turn on at your desired current level.
The opto-coupler in the previous pic is then followed by a emitter follower (Q1) and low current/voltage self latching relay.   The second set of contacts are used to actuate the amplifier's own shut down circuitry.
If the amp is a multi-tube affair you can simply "OR" the opto-couplers as in the pic below.
My brief article can be found HERE, scroll down to restoration/repair projects to "Screen grid protection"
Mike KE0ZU
N8ETQ
Mort
« Reply #2 on: September 08, 2016, 08:30:30 PM »
    Ya,
        Gotta lash it up better. E scr should be
disabled until Ep is present.  The only thing I
worry about loss of Airflow.  Also easy to alarm.
Just need a "Round To It"...
         Sri about the jug....
/Dan
John K5PRO
« Reply #3 on: September 09, 2016, 03:50:47 AM »
Even simpler is to use a series R off the HV and feed a high resistance relay, 5000 or 10000 ohm coil resistance, Use the contacts to turn on the screen V. No need for silicon or tubes even.
« Reply #4 on: September 09, 2016, 10:41:48 AM »
Darn tootin'. A sensitive latching relay is connected across a rheostat in the screen circuit of the 4-1000 here and it does indeed trip without delay, and illuminates a lamp on the front panel. It's unlatched by the front panel push button. The rheostat gives a wide variety of trip points. I think it's set about 150mA.
If there is a time delay or integration wanted so that a momentary pulse or excursion won't trip it, a small oil cap can be put across the rheostat.
If it is wanted to trip more hastily upon the onset of a very large current, an additional voltage dropping resistor can be put in series with the rheostat, and a small oil cap can be put across that.
I have not permanently added either 'enhancement' only played with this, and never blown a 4-1000 screen using the simple no-C circuit shown despite several major incidents.  I like the R off the HV supply to a relay but what's already there is OK.
look ma, no silicon!  is the point
« Reply #5 on: September 10, 2016, 08:32:42 AM »
If the high impedance relay is sensitive enough, just place it in the bottom of your high voltage meter reading string in proximity with the meter.   A couple of resistors ought to get it about right in that area yet keep the meter reasonably accurate.
E.g., A "Y" split at the bottom of the HV resistor string, one for the relay and one for the meter.
