May 13, 2024, 10:23:06 PM *
Author Topic: Valiant Modulator Bias Problem  (Read 14481 times)
W1KSZ
« on: March 14, 2014, 01:26:32 PM »
The Bias control (a pot) does not have the same effect on plate current it
used to have.
If I turn the pot to "zero", I get "zero" plate current. Advancing the pot
shows zero plate current until it suddenly jumps to 100 ma. Turning the pot
back does not affect the plate current until at a point it drops to zero.
I thought the pot had gone bad, but a test with an ohmmeter shows it
to be good.
I checked the bias voltage (at the pot wiper) with an Analog Meter and
it varies from ~-87 vdc on down with no hickups in the reading.
Any thoughts ??
73, Dick, W1KSZ
« Reply #1 on: March 14, 2014, 01:41:58 PM »
Dick
Check the connections from the meter to the shunt resistor that is used to measure the modulator plate current.
It could be a cold solder joint.
It could be oxidation (particularly on the positive side) of the associated meter switch contacts.
Check both the + side and the ground side of the meter connections in the "modulator" position. I.e. the switch lifts the ground side connection in the "plate" position, so you can't assume that the ground side connection of the meter is okay in the "modulator" position.
« Reply #2 on: March 14, 2014, 02:23:56 PM »
Dick,
Pull the modulator tubes and check the bias voltage at the grids to see what it shows.  Either check the modulator screen voltage VERY carefully or to be safe with the power off and HV discharged put the rig in the phone position and measure resistance from the screen terminals to the output of the HV filter choke.
W1KSZ
« Reply #3 on: March 14, 2014, 02:53:29 PM »
I checked the resistance and it reads 12K. The Screen voltage reads +218 vdc
on my trusty $2 Harbor Freight DVM. I'll check the bias as soon as the HV cools
down.
73, Dick, W1KSZ
VE3AJM
« Reply #4 on: March 14, 2014, 03:04:43 PM »
Could it possibly be a meter shunt value issue?
Al VE3AJM
W1KSZ
« Reply #5 on: March 14, 2014, 03:25:35 PM »
The symptoms are non-linear, you can turn the pot 10 or 15 degrees
and nothing, then all of a sudden, plate current drops to zero from
around 150 ma or so. No adjustment between those two points.
73, Dick, W1KSZ
« Reply #6 on: March 14, 2014, 03:26:28 PM »
Before checking bias voltage check the mod cathode resistance to ground before turning power on.  It should read near zero.
If you don't have any spare 6146 tubes (any 6.3 variant of the family) for testing then it is safe to put 1 tube at a time in the modulator with no audio drive and see if that uncovers a bad tube IF the previous bias and resistance checks don't indicate an issue.
« Reply #7 on: March 14, 2014, 06:28:13 PM »
I agree that the problem could be a loose or corroded connection between the ground side of the cathode meter shunt resistor and chassis ground.
At low enough settings of the negative grid bias, this bad connection might arc through. If you make the grid bias negative enough it might open up again.
In between, it might be very non linear in terms of its I-V characteristic.
W1KSZ
« Reply #8 on: March 14, 2014, 06:38:48 PM »
I found a spare set of 6146's (sitting in the Seneca I just got), I know they
work, I get 150 watts out on 6 from the Seneca.
Well, same problem ... so, the only thing left is the shunt resistor, buried
under some transformer. Guess I'll take a crack at removing it to see if
there's something wrong under there.
Thanks for all the replies, I'll post my findings on the shunt resistor.
73, Dick, W1KSZ
W1KSZ
« Reply #9 on: March 17, 2014, 07:19:43 PM »
I finally got back to the Valiant after some delay.
I had to remove the Finals Bias Pot to get to a screw holding in
the choke blocking view of the Mod tube sockets. All looks well
in there.
Now it gets stranger, in fiddling around I noticed the Audio Gain
Pot will change the MOD current as I turn it. The higher I turn it
the lower the current Huh
I thought it may be oscillating, but I listened on another receiver
and there is no sign of oscillation.
Anyone have any ideas on this one ??
Tnx, Dick, W1KSZ
« Reply #10 on: March 17, 2014, 07:42:50 PM »
Dick
This now seems like an oscillation problem, even though you haven't detected any oscillation. With all of the audio stages being AC coupled, it is hard to see how the audio gain pot would effect the resting cathode current in the modulator, except as a result of some kind of oscillation.
Try removing the tube in the audio chain that drives the modulator output tubes, and see if you can then properly adjust the modulator resting current.
« Reply #11 on: March 17, 2014, 08:09:55 PM »
Check the decoupling caps in the B+ chain that feed the audio circuits.
« Reply #12 on: March 17, 2014, 08:15:19 PM »
I remember somebody having some strange modulator issues when one of the 22 ohm resistors in the plate leads went up in value.  Take a look at them.
« Reply #13 on: March 18, 2014, 09:54:31 AM »
Dick
Put a scope on the RF out (go to dummy load, of course)
See if your scope either goes all fuzzy or you actually see an oscillation on the envelope.  If it acts normal while on the dummy, maybe you have an RF in the shack problem.  You might not hear a tone is the oscillation is ultrasonic (beyond your hearing of your receiver)
« Reply #14 on: March 18, 2014, 12:39:44 PM »
Dick
Further comments:
If there is an oscillation in the audio section, the audio oscillation frequency might be very high (ultrasonic). A high audio frequency oscillation would be greatly attenuated by the mod transformer, and by the presence of all of the .01uF capacitors (TVI filters) that are between the modulated B+ and ground in a stock Valiant. Therefore, you might not see or hear much modulation on the RF envelope of the transmitter's output.
Note that, looking at the schematic, there is no audio frequency bypass capacitor across the modulator bias supply (i.e. between the center tap of the secondary of the audio driver transformer and ground). The overall negative bias supply is bypassed; but the fraction of this overall negative supply voltage that goes to the modulator (via the voltage divider that includes the modulator bias adjustment pot) is not bypassed. Adding a 10uF capacitor from the center tap of the secondary of the audio driver transformer (or from the wiper of the modulator bias pot) to ground would be a good idea to try. [Note that the + side of the capacitor should be connected to ground.]
Note, also, that the clipper (being a non-linear function) could increase the tendency of the audio section to oscillate if it is not functioning properly.
I was also thinking about the screen voltage regulator (two VR tubes in series). If they were switching on and off, that would cause the screen voltage to jump up and down. However, that doesn't fit with the symptoms.
If there were a bad connection between the HV supply and the regulators (via the 12kohm dropping resistor) that might be causing the screen voltage to be turning on and off. There are a number of switch contacts in that path.
W1KSZ
« Reply #15 on: March 18, 2014, 07:00:08 PM »
I pulled the 12AU7 Driver tube and I could adjust the Bias quite easily.
Thinking the tube might be bad, I changed it, no dice.
I then started probing with a scope;
Pin 6 - 6C4: No sign of oscillation
Pin 5 - 6C4: Shows signs of oscillation as soon as the Mod tubes draw
current
Pin 2 - 12AU7: Same as above.
Now, this rig was working OK, I made a couple of Q's with it and got
decent audio reports.
Also, it's been heavily modded in the Audio section, from comparing
schematics, it looks like the W6BM mods were done to it (after all
we are closer to the West Coast !!).
Open for suggestions.
Tnx, Dick, W1KSZ
« Reply #16 on: March 18, 2014, 10:20:09 PM »
Tnx, Dick, W1KSZ
That explains why your set is not working, it's all that foggy, smoggy West Coast air. Grin
« Reply #17 on: March 18, 2014, 10:32:57 PM »
Dick
Now try to see where the feedback is entering the audio chain.
Start by unplugging the microphone. See if that makes the oscillation stop.
If the oscillation is still there, remove the microphone preamplifier tube.
W1KSZ
« Reply #18 on: March 19, 2014, 01:12:07 PM »
Here's what I tried and the results:
Connected Mike, still oscillated.
Pulled 12AU7 (Driver), Oscillation stopped.
Replaced 12AU7, still oscillated.
Pulled 6C4, Oscillation stopped.
Replaced 6C4, still oscillated.
Pulled 12AX7, still oscillated, OK, now it's got
to be downstream from the Mike Pre-Amp tube
(12AX7).
I replaced the Cathode By-Pass cap on the 12AU7,
still oscillated.
At this point I am stumped. Any recommendations ??
Tnx, Dick, W1KSZ
« Reply #19 on: March 19, 2014, 01:49:37 PM »
Mike
If there are mods, then I'm probably not looking at an accurate schematic (I'm looking at the stock Valiant schematic on the BAMA website)
If the clipper is still part of the circuit, try removing the 6AL5 clipper tube to see if that stops the oscillation.
Separately, has feedback from the modulation transformer's output to the 6C4 been added as an audio mod?
W1KSZ
« Reply #20 on: March 19, 2014, 01:55:23 PM »
The rig has been modd'ed along the lines of the W6BM mod's. The Clipper
has been removed and the Feedback mod added.
I'll try breaking the feedback line to see what happens.
How important is this feedback mod ? Does it really improve the audio
that much ?
But, the rig did function earlier, got decent audio reports, so it's
something recent that happened.
I'll report back on my findings.
73, Dick, W1KSZ
« Reply #21 on: March 19, 2014, 02:04:55 PM »
Mike
You said that the transmitter was working okay before this problem arose.
Between the time it was working okay and the time the problem arose... did you by any chance remove the plate caps on the modulator tubes (maybe to change tubes) and then reinstall the plate caps on the opposite modulator tubes. Doing so would switch the polarity of the feedback from negative to positive
The feedback isn't critical, but it probably helps a little if it is implemented correctly
W1KSZ
« Reply #22 on: March 19, 2014, 02:10:51 PM »
I broke the feedback loop and I can now adjust the Modulator bias
as before. Now to find out if that feedback really does make an
improvement, else I am ripping it out.
The only time I removed the Modulator tubes was after the problem
appeared. And the added feedback line to one of the plate caps
makes it near impossible to switch them.
So, possibly some component in the feedback loop went bad, no
problem if I just remove it all !!
73, Dick, W1KSZ
« Reply #23 on: March 19, 2014, 02:17:02 PM »
Does the feedback come back to the 6C4? If so, can you provide some details as to where it is connected.
Typically, one would use a capacitor to ground, at the point where the feedback is inserted... of suitable value to roll off the feedback ratio at higher audio frequencies.
W1KSZ
« Reply #24 on: March 19, 2014, 02:36:08 PM »
Feedback comes back to the cathode of the 6C4. It consists of two
0.22 mfd 600 vdc caps in series, two 47K 2W in series, a 4.7K 5
Watt thence thru a 680 ohm 1/2 Watt to pin 7 of the 6C4. Pin 7
also has a 1.2K 1/2 Watt to ground.
Lots of parts, for what purpose ??
73, Dick, W1KSZ
Page created in 0.064 seconds with 18 queries.
