June 04, 2024, 04:36:12 PM *
Author Topic: Hallicrafters SX-88 Drive Belt Question:  (Read 2759 times)
n2len
« on: August 22, 2011, 02:50:52 PM »
If someone is interested in manufacturing a drive belt for the SX-88 I have the exact measurements as taken to make the belt mold.
A gentleman who was spearheading this belt project decided not to proceed several years ago. A quote of $3700.00 was given to produce the belt mold. If someone has any specific information of someone who can actually produce a belt mold, I would gladly supply the detailed exact measurements for the SX-88 drive belt. I am not looking to make any profit from this. Just looking to help those that need this very rare part to get there SX-88 back online.
Len N2LEN
« Reply #1 on: August 22, 2011, 11:59:18 PM »
As I've previously related, I found a belt with the right tooth pitch and length but twice as wide at a surplus store.  I just split the belt down the middle with a razor and got two good belts out of it.  Don't discount an otherwise correct belt that's too wide if there's a standard one in a belt catalog.
« Reply #2 on: August 23, 2011, 12:26:17 AM »
3700 dollars for a mold.  What about the cost of making the belts.  How many belts could you possible sell at any price to recoup the investment??  Could you sell a hundred belts at $37 each?
I'm not sure what this belt looks like but there's probably a standard belt of some size that could be made to work.
You may do better by checking with a company that makes belts,  they may be able to make a number of belts cheaper overall.
Is this belt some sort of timing belt (belt with teeth)?
n2len
« Reply #3 on: August 23, 2011, 07:48:17 PM »
Hello Fred,
Yup $3700 dollars was the price quoted on the invoice I received from the gentleman who was interested in trying to get an exact sized belt produced. When he received the quote, he just decided it was a way too expensive project. He recently e-mailed me a copy of the actual quote which has the specific measurements for producing a belt mold.
So I was offering the information to someone who may have a contact in the belt industry.
« Reply #4 on: August 23, 2011, 11:30:08 PM »
The problem is that the tooth pitch is non-standard.  Apparently the tooth pitch on this belt is .25" whereas standard pitches are .2" or 5 mm.
You can get toothed pulleys easily enough.  It might be easier in the long run to replace the pulleys with standard tooth pitches and use a standard belt.
Page created in 0.032 seconds with 18 queries.
