May 29, 2024, 05:53:07 AM *
Author Topic: Geloso  (Read 8751 times)
« on: June 25, 2011, 07:20:32 PM »
After seeing what great work Andrea IW5CI is doing with classic U.S. gear in his SX-28 thread I thought it was important to acquire some classic looking Italian vintage gear to keep the planet in balance Smiley  A few months ago I acquired a Geloso G4/215 receiver and started looking for the matching G4/225 transmitter.  I now have the setup and although working they will soon go on the bench for a full inspection and alignment.  I do need to acquire some missing metal discs for the knobs and it would be nice to find a new dial cover for the transmitter (it has a crack on one side) but that is not likely to happen soon.
The receiver is dual conversion with a single crystal style filter in the 467 Kc. second IF.  The transmitter is a phasing type rated at 100 watts output SSB/CW and 25 watts AM from a pair of 6146 tubes.  Both were made in 1965 and cover 80-10 meters.  The transmitter VOX system is located in the separate power supply.  It came with a Geloso microphone which will take a little getting used to, the microphone head lifts out of the stand when you pick it up instead of being permanently attached to the base.  I think it will be easier to modify the microphone than my behavior Smiley
« Reply #1 on: June 25, 2011, 07:21:38 PM »
and a few more photos
« Reply #2 on: June 25, 2011, 08:45:36 PM »
I always thought the Geloso transmitter was like the Italian version of the Johnson Valiant.  Wink
« Reply #3 on: June 25, 2011, 10:23:22 PM »
That is a fascinating looking pair.  Is Geloso pronounced with a hard or soft G?  I am a little surprised the front panels are labeled in English.  I wonder if there were export and domestic models.
KA0HCP
« Reply #4 on: June 25, 2011, 10:48:13 PM »
I think the Geloso's look  very stylish.   Bright and uncluttered.  The microphone is a real catch.
Mr. Geloso was quite a clever and interesting man.  He worked here in the US for several years (I think with Mr. Hammarlund) before returning to Italy.
« Reply #5 on: June 25, 2011, 10:49:51 PM »
Rob,
I don't know which is the proper pronunciation.
The manuals that came with the gear are in both Italian and English (well a few sections are Italian only) but all of the photos of the gear show it is labeled in English.
« Reply #6 on: June 26, 2011, 12:22:18 AM »
A beautiful rig, Rodger!
KX5JT
John-O-Phonic
« Reply #7 on: June 26, 2011, 12:52:32 AM »
I think the G is soft.  Most hard G's with the e following have a second vowel, like gear, Geiger....
AMI#1684
vincent
« Reply #8 on: June 26, 2011, 04:44:02 AM »
An interesting link for the Geloso Story (in English):
http://www.qsl.net/i0jx/geloso.html
Geloso means Jealous, the G is pronounced like the J.
« Reply #9 on: June 26, 2011, 11:23:03 AM »
There doesn't seem to be a crap load of their stuff in the US but from what I can see, it looks like good equipment and I wouldn't mind having some Smiley Smiley Smiley
W1UJR
« Reply #10 on: June 26, 2011, 04:08:45 PM »
Cool stuff Rodger, you needed those!  Wink
Think I've seen one of those at HossTraders some years back, not as pretty as your sets.
Radio on OM.
« Reply #11 on: June 26, 2011, 09:23:50 PM »
Rodger,
           In your pix, you missed the money shot!! You should show the underside of the chassis!! For those who've never seen one, Geloso stuff from that era has the neatest wiring and cleanest chassis layouts I've ever seen!! True craftsmanship, and beauty to behold! ! ! ! ! ! ! ! ! !
One of the FEW things I dislike is the crapstal carbolator. It uses harmonics of 3500Kc instead of 100Kc only enabling you to cal the bottom of each band. (at least that is the way mine is)
« Reply #12 on: June 26, 2011, 09:36:09 PM »
Bruce,
I am not sure need is the right word but they are a fun setup.  Compared to the other radios I have been working with lately the Geloso gear is refreshingly lightweight.
Slab,
I will take a better look at them now that the HT-30 is off the bench.  This receiver also has the 3.5 Mhz. calibrator crystal, it was such a great idea Hallicrafters used it in the SX-140 Smiley
The cute little microphone is going to get some removable adhesive used at the joint between the head and the base before I accidentally send the base flying into something.
« Reply #13 on: June 26, 2011, 10:10:27 PM »
heatest wiring
Do they employ special wiring perhaps Teflon?
« Reply #14 on: June 27, 2011, 07:37:59 AM »
Rodger,
Looks like a fun project.  I have never seen one up and close but have always heard that they were well done.
At first physical glance, they have a shade of similarity to some of the Elmac transmitters.  Functional equivalency seems similar to an HT-37.
When you have the pieces belly up, it would be good to see some underneath shots.
Have fun!
Joe, W3GMS
« Reply #15 on: June 27, 2011, 08:01:25 AM »
heatest wiring
Typing too fast when tired.................. Should have been - - -neatest  Shocked  Grin
« Reply #16 on: June 27, 2011, 08:08:19 AM »
The G is pronounced like a J.    Hence: Jeloso in english.
(there is no J in the Italian alphebet)
I have a Geloso receiver, (dont remember which model number) but it is similar in appearance to Rodgers. It is a good, solid performer and quite a pleasure to use.
vincent
« Reply #17 on: June 27, 2011, 08:45:40 AM »
In the good old days when Geloso was in vogue I was not very attracted by their equipment (though I used their “Gruppi RF” and transformers) I was more attracted by the American radio equipment. Now I have to admit that they were not so bad, it’s a matter of nostalgia?
« Reply #18 on: June 27, 2011, 12:15:28 PM »
ZEQ used to run a Geloso 500 aka a JJ 813 rig Grin Grin Grin
I could never understand his humor? I told him once on the air, there is no such thing and he went off on me like you wouldn't believe!!
Page created in 0.043 seconds with 18 queries.
