May 25, 2024, 03:29:45 PM *
Pages: 1 ... 6 [7] 8   Go Down
Author Topic: FUEL $$$ WTF  (Read 117177 times)
« Reply #150 on: April 27, 2011, 11:25:10 AM »
You obviously weren't doing it right.  Sidestep that clutch, man  Grin
« Reply #151 on: April 27, 2011, 11:41:08 AM »
Been there, done that!! Used to pop the glovebox open and launch all of it's contents into the lap of whoever was sitting in the passenger seat
« Reply #152 on: April 27, 2011, 11:46:46 AM »
I used to get 3,000 miles out of the clutch in my 340 'Cuda.
Day-um !
Twice we have squeezed a quarter million miles out of the original clutch in cars we bought new.
Sold a 90 Corolla with 240,000 mi, clutch still hi hi FB
Sold a 95 Camry with 260,000 mi, also hi hi FB clutch OM.
Of course, neither of these cars would launch your lunch from the console to the backseat on takeoff.
But at 30mpg, it's times like this they're good commuter cars.
« Reply #153 on: April 27, 2011, 11:57:30 AM »
Paid 3.899 today for reglah. That does make driving your Hot Rod a special (and costly) treat  Cry  Cry
« Reply #154 on: April 27, 2011, 12:02:55 PM »
Dood, I run a mix of Cam2 in the Electramobile.
Hate to see what THAT's up to, next time I tank up.
http://www.bazellracefuels.com/racingfuels.htm#CAM%202
Ralph W3GL
« Reply #155 on: April 27, 2011, 12:07:59 PM »
   Clutch, what's that?
   A little timing, get the revs correct  and flip the lever when right and you
   don't need no stinking clutch peddle...
   My old '37 Dodge worked fine like that but of course it took some practice
   and the shifter might have had a tooth or two end up in the housing sump...
    Wink Wink Cheesy Cheesy Grin Grin Grin
73,  Ralph  W3GL
« Reply #156 on: April 27, 2011, 12:15:41 PM »
P,
Where can one buy that cheep gas??
« Reply #157 on: April 27, 2011, 12:19:18 PM »
Picture is from early March, true, but I got straight gas (87) for 3.83 yesterday, not too far off.
« Reply #158 on: April 27, 2011, 12:20:34 PM »
That's exactly what I was doing. Just a whole lot : )
« Reply #159 on: April 27, 2011, 12:50:09 PM »
I just paid 4.19 for 89 juice yesterday.
Poor oil companies need a tax break.
« Reply #160 on: April 27, 2011, 01:05:35 PM »
You need 89 in that truck?
I've always used 87 for everything.  There was a time when I added a water injection kit to keep the detonation down and advance the timing some more. Worked great.
See ya at Nearfest Fri/Sat, OM.
« Reply #161 on: April 27, 2011, 02:05:27 PM »
In many cases, 89 octane is reached by blending ethanol with 87 octane.  Since alcohol BTU content is lower you also lose MPG in the bargain so stay away from higher octane unless you have to use it.
The 3.6 V6 in my Cadillac CT has a 11.3 to 1 compression ratio and runs fine on the recommended 87 octane regular gas courtesy of the direct fuel injection system.  The manual cautions that the standard port injected version (with 10.2 compression) may require 89 octane under some conditions.
Unfortunately in IL it is very difficult to find even 87 octane that hasn't been cut with ethanol, there is one local station that still has it.  Diesel here also contains an unknown amount of bio between 9-21% but that is less bothersome than ethanol and does have some real benefit for the injection system (as long as it isn't really cold).
With fuel being diluted with "food products" I hope that the dairy guy doesn't get revenge and start dumping used motor oil in my 2% milk Smiley
« Reply #162 on: April 27, 2011, 02:19:06 PM »
Day or two ago saw $4.29 here for 87.  But, a few miles west on the other side of town found 7-11 selling 87 for $4.03.
I went inside and handed over all  the cash I had on me which came to $47 and said put all that on twelve outside and it got me up to 3/4 of a full tank.  I hadn't planned on doing that but I figured I may not see $4.03 again for awhile.
« Reply #163 on: April 27, 2011, 03:39:49 PM »
Interesting Huh  Huh I wonder if that is area specific?? My Ranger gets noticably better mileage on 89 than it does with the 87. Oftimes enough to warrant the extra cost.
« Reply #164 on: April 27, 2011, 04:34:28 PM »
I wonder if your Ranger needs 89 to avoid retarded timing (via an electronic knock sensor)?  Maybe some carbon buildup?  Not all 87 octane is pure gas, here is a link to a group that lists ethanol free stations but it is user built so check before you fill:  http://pure-gas.org/index.jsp
The use of ethanol to increase octane has been common throughout the midwest region for quite awhile, probably strongly correlated with the corn/ethanol lobby Sad
For awhile it was also an EPA listed oxygenate to meet specific air region/city air quality requirements but I think that has ended.  Of course the latest tomfoolery is the move to increase ethanol content from 10 to 15%.  Think of it as the EPA version of BPL, don't let science get in the way of revenue.
K6JEK
RF in the shack
« Reply #165 on: April 27, 2011, 10:29:43 PM »
$4.29 regular $4.69 for super.  I drove through San Francisco on my way up north today and those were the prices. My understanding is that's down from the peak there.  When I was a kid, we called the high octane stuff ethyl.  I wonder what that was about.
« Reply #166 on: April 28, 2011, 12:35:11 AM »
From the addition of Tetra-Ethyl Lead.
« Reply #167 on: April 28, 2011, 08:49:22 AM »
Rodger,
           We get stuck with that oxygenated szht around here during the summer.
What crap!! There is a noticable drop in fuel economy with that junk! ! ! ! !
"This fuel has been oxygenated to reduce emissions" B.S.! ! ! ! ! It has been oxygenated to reduce the thickness of your wallet!!
« Reply #168 on: April 28, 2011, 09:16:44 AM »
I found 89 gives me better mileage and less cents per mile. Also runs better.
91 runs even better but costs more cents per mile so 89 gives me best economy.
« Reply #169 on: April 28, 2011, 09:18:47 AM »
That has pretty much been the case here as well.
« Reply #170 on: April 28, 2011, 10:25:48 AM »
If you go to Iowa you find the 89 is 10 to 20 cents less / gallon than the 87.   turns out it is subsidized -- has something to do with corn gasohol.  Lotta corn in Iowa.
« Reply #171 on: April 28, 2011, 11:31:33 AM »
A little far to drive, just for a fillup  Grin  Grin
« Reply #172 on: April 28, 2011, 01:10:32 PM »
$3.99 for 87 this morning in Northern Ohio.
We got us an ol' fashion gas war going on. None of the stations wanna be the first to put $4.00 on 87.
« Reply #173 on: April 28, 2011, 01:23:21 PM »
What kind of gas mileage do you get with your CTS, Rodger?  Last trip I took to Delphi (part highway, part windy mountain road) I got about 30 MPG with mine; 3.6L/6 speed manual.  With $9.50/gal gas here I don't drive the Land Rover much  Grin
W2XR
« Reply #174 on: April 28, 2011, 01:46:13 PM »
I paid $4.11/gallon this morning for 87 octane here on Long Island, Buddly. And that is for cash. My wife and I stopped using the credit card for gasoline purchases a few months ago, as the filling stations in this area charge an extra $0.10/gallon for credit card sales. Ten cents/gallon adds up over time, and I won't give the service station the satisfaction of making an extra dime per gallon off of me just for a credit card transaction. Wink
And I passed by one station after filling up that was charging $4.59/gallon for 87 octane fuel. My guess is that the filling station where I gassed up today will be charging $4.59 for 87 in the not too distant future.
It's still a bargain compared to paying $9.50/gallon in Greece. My guess is the Greeks tax the hell out of gasoline, especially considering the severe economic conditions they are currently experiencing.
Bruce
Pages: 1 ... 6 [7] 8   Go Up
Page created in 0.091 seconds with 18 queries.
