May 10, 2024, 03:05:40 PM *
Author Topic: HQ-170 120 Hz audio hum  (Read 5816 times)
WB4AQL
« on: February 03, 2011, 11:04:29 AM »
Hello everyone. Spring is coming!
I have been chasing a persistent 120 Hz audio hum that is present at constant volume and unaffected by the volume control or standby/rcv mode. Not deafening, but loud enough to be a bother. Cathode bypass caps in audio stage are new and tubes have been swapped. My first suspicion was heater to cathode leakage, but I think I`ve chased those possibilities. Multi-section can filter cap has been replaced. I thought sure that would stop the hum as the 60 mfd section is the cathode bypass for the 6AQ5!. Didn`t change a thing.
There does seem to have been a previous owner mod in the audio section involving the 1st audio 6AV6 and final audio 6AQ5. I know there were some mods to "improve" the HQ-170 audio, but I can`t seem to find a description. Hard to believe that any wiring changes for "improvement" would have intentionally induced 120 Hz hum.
I know Hammarlund put out some tech bulletins concerning hum. I`ve been through those. Just wondering what ya`ll think.
73, Michael  WB4AQL
« Reply #1 on: February 03, 2011, 11:36:15 AM »
just a thought:
Most of the negative feedback mods for the gray faced Hammarlunds create some type of feedback loop from the plate of the 6AQ5 back to the plate of the first audio. Now, the audio output is fed B+ from the input side of the CLC filter. (before the choke) I have done these mods before and gotten some hum in the audio. I have usually cured it by moving the feed for the 6AQ5 plate and screen to the output side of the B+ filter. (after the choke) (I dont remenber if they had a small choke or just a resistor) I cant check the skizmatic cause I'm at work. A little careful investigation should tell the tale.
WB4AQL
« Reply #2 on: February 03, 2011, 12:17:33 PM »
Slab, I think you are in the neighborhood. One part of the mod has a 1 megohm 1/2 W resistor in series with a 0.01 mfd ceramic disc connected back to the cathode of the first audio 6AV6.
Michael
WB4AQL
« Reply #3 on: February 03, 2011, 01:06:53 PM »
Also, I can`t find the cathode bypass capacitor at all for the 1st audio 6AV6. It should be a 20 mfd 25V electrolytic. I think it was removed during the mod-can`t imagine why. Guess it`s absence could be contributing some hum.
Michael
« Reply #4 on: February 03, 2011, 01:08:51 PM »
Michael
That's it!! I believe it was Larry's  (W8ER or whatever his call is now) mod. Try snipping the joint between the resistor and cap and see what happens. If that cures it, it's your decision- improved audio, Hum, or relocate the B+ feed for the outpoot tube.
« Reply #5 on: February 03, 2011, 01:12:08 PM »
Michael
Michael,
           You have to remove it for the feedback mod to work or it would bypass the inverted audio right to ground. It being missing, is not going to cause your hum.
WB4AQL
« Reply #6 on: February 03, 2011, 02:08:18 PM »
Slab! Hum is gone!! It was the feedback from the audio mod. I`ll have to find a decent AM signal to critique audio, but not  missing that hum.
Should the cathode bypass cap on the 6AV6 be re-installed? Seems to work FB without it.
Man thanks OM.
Michael  WB4AQL
WB4AQL
« Reply #7 on: February 03, 2011, 02:26:37 PM »
Regarding the bypass cap-that is IF I leave out the feedback circuit...
Michael
« Reply #8 on: February 03, 2011, 02:28:37 PM »
Then don't replace the cathode bypass cap. Without it you get some negative feedback.
Michael
« Reply #9 on: February 03, 2011, 02:39:33 PM »
Michael
Without it you will get a little degenerative feedback. It is your decision, try it both ways and see which way you like it better. Dont expect breathtaking audio from an
HQ-170, though. The IF bandwidth is far far too narrow for anything HI-FI. they are, however a good "battle conditions" receiver. (I have one) You may also want to disable Hammarlund's crappy "Auto Response" circuit. I have yet to find a good excuse for them.
But that is up to you. (if it has the feedback mod, it has prolly allready been done)
WB4AQL
« Reply #10 on: February 03, 2011, 02:52:15 PM »
Okey doke. Thanks to all.
Michael
« Reply #11 on: February 03, 2011, 03:19:07 PM »
I too have one of those receivers. It has quite a hum. It does not have a three way plug on it with a ground to the chassis. I need to do that as voltage appears on the chassis.  It is enough to give you a tickle.
Well anyhow the point I'm trying to make here is that I greatly reduced the hum just by reversing the ac plug at the wall socket.
