I am trying to rebuild 2 Globe King 500's. One is a 500 and the other is a 500B. Both have L6 missing. This is the 2.5 inch dia. coil under the rf chassis in the final tank circuit. I need to know how many turns are on it and are they close wound or spaced. Is the wire #16 like that is on the coil above chassis?
WB4NKL
This must be a fairly common problem. My GK 500B is missing that coil.
It provides series inductance to enable the radio to match 160M to a 300 ohm output Z. I never bothered to put something in there since I don't operate on 160 (no space for wire), and it isn't used on any other band. Figured if it came to it at some point, a small rotary inductor in series with the output would make a reasonable sub.
Grant/NQ5T
