June 22, 2024, 09:31:41 PM *
Author Topic: Re-attaching 811 plate contacts  (Read 9585 times)
KA1ZGC
« on: March 16, 2008, 12:40:15 PM »
Hey Guys,
I have the worst luck with 811s.
I pulled the toobz out of the Junkyard Dawg a little while ago, and when I pulled the plate cap off one of the 811s, the contact came right off the envelope, leaving just a piece of wire sticking out of the top of the glass.
The seal is still good, and it looks like I can re-solder it, but I'm wondering if there's anything else I can do at this point to help the situation.
Any caveats or helpful hints you guys can pass along? I've never done this before, and I'm wondering if there's anything I can do to help re-seat the cap so it's less inclined to pull off from the envelope in the future.
Thanks in advance.
--Thom
Ed-VA3ES
« Reply #1 on: March 16, 2008, 01:29:46 PM »
Prep the plate cap in he following manner:   Get some J-B Weld.  Prep the solder hole in the cap by cleaning it out.   Put a very small amount of the J-B Weld  on the bottom of the cap.  Solder the cap to the wire, and press the cap down to force the J-B Weld onto the envelope.  (You may have to scrape the extra J-B Weld off).  Wait about 24  hours.    Done.
J-B Weld is highly heat resistant.
K1DEU
« Reply #2 on: March 16, 2008, 01:39:21 PM »
I have cleaned the Glass and dug and scraped out the plate cap. Then used Crazy Glue curing in a 70 degree room about an hour. Many times before, John
« Reply #3 on: March 16, 2008, 10:12:51 PM »
I've been told that the flowable silicone rubber works ok fine here...
I have yet to try it.
They sell it at auto parts stores for windshield repairs among other uses.
It works fine and dandy on loose bases for sure, that I've tried.
          _-_-Wombat Bear Two Goats Cougars Raptors
W2JBL
« Reply #4 on: March 17, 2008, 01:06:16 AM »
  none of the consumer grade epoxies, "crazy glues" or silicone sealers can stand the kind of heat dished out by a hot tube in a big maul. i use furnace cement, just like we use to patch holes on woodoline stoves. it's water based, and cures best when heated. it also bonds really well to glass. comes in little tubs like margarine from the hardware store. as mentioned above clean everything nice like a good boy scout, especially the wire coming out the top of the tube so you get a nice slobber connection. the stuff its truly excellent for re-gluing tube bases too in case you get a bit hammy handed yankin' those bottles out of their sockets. best of all it won't burn. i have spots on my woodoline stove patched with it that run near red hot and have held over ten years.
W7SOE
« Reply #5 on: March 17, 2008, 05:37:50 PM »
I would send you some "refractory mortar" that I have but the envelope would bust open at the post office and I would spend the rest of my days at Guantanamo.   Tongue
Rich
Carl WA1KPD
« Reply #6 on: March 17, 2008, 08:00:52 PM »
I have had trouble with some tubes breaking at the top after using "Crazy Glue" type material. I understand that the cure process can involve very high momentary heat that weakens the glass.
YMMV
Carl /KPD
« Reply #7 on: March 18, 2008, 08:20:38 AM »
FWIW, I have been using "krazy Glue" to reatach loose plate caps and tube bases for years and never had any problems. Many of the 2 part epoxies seem to soften with heat. Like others have said YMMV.
Carl WA1KPD
« Reply #8 on: March 18, 2008, 08:55:38 AM »
I often use the acceleration spray with it. Maybe that is the issue?
« Reply #9 on: March 18, 2008, 11:57:04 AM »
My limited understanding is that there is more than one type of refractory cement...
Wonder which type(s) are good with metal and glass?
Brands?
Uncle Tim's Olde Tyme Gook??
                                    _-_-woobly bearing two grainy crunchy reamers
« Reply #10 on: March 19, 2008, 01:02:45 PM »
Just use a clip lead. You don't need no plate cap.
« Reply #11 on: March 19, 2008, 01:14:51 PM »
I was thinking about this last night, and wondered if the liquid porcelain would work.  My Mom used to buy it when she was working with glass, and it seemed to work nicely.
Seems heat resistant, a good insulator, and cures in a decent amount of time.
Any ideas from those with more knowlege?  Stained glass shops (and others) had these in the past.
Carl WA1KPD
« Reply #12 on: March 19, 2008, 01:24:59 PM »
Clip lead?
I just remove the twist the wire to the  together with the plate lead
« Reply #13 on: March 19, 2008, 02:09:12 PM »
You can solder the lead on and unsolder it when the tube needs to be replaced....  I wonder what kind of stuff the tube manufacturer used to fill up the void in the cap originally?
KA1ZGC
« Reply #14 on: March 19, 2008, 04:55:14 PM »
TNX fer all the suggestions, guys.
For the moment, the cap has been slobbered back on to the lead. Nothing else has been done. I'll be pulling that tube again in the near future, and I'm sure it'll yank back off from there again, so I'll get the chance to try out some of these suggestions.
I've often wondered what that brown cruddoline is they filled those caps with when they jammed them on the top of the tube. Probably nothing I want to play around with.
I can't go the clip-lead route because the tube is within an inch of the blower for the RF deck. Slobbering to the plate lead isn't an option because I need to pull those tubes to safely pull the RF deck (they're taller than the modulator chassis).
I'll be picking up some more 811s (and 4-250s, 4-400s, etc.) during the hamfest season, but I need to keep this one alive (and removable) until then. I plan to do more work to this transmitter during the spring and summer months.
For now, it's fresh slobber and a prayer. When I revisit this problem, I'll give a stab at some of your ideas.
Thanks a bunch, guys.
--Thom
Killer Agony One Zipper Got Caught
« Reply #15 on: March 19, 2008, 05:36:58 PM »
Thanks in advance.
--Thom
Actually, I have been thinking of Fahnestock clips for this kind of problem.  Why stress a perfectly good 811A?  You could have two sets of plate connections -- with and without plate caps.  I think we all know better than to have our hands near this stuff when the HV's on.  You could say the plate caps are eye candy.
http://www.sargentwelch.com/product.asp_Q_pn_E_WLS31067-05_PK_A_Fahnestock+Clip+Connectors_E_
Al, VTP  See you on Yay YM
« Reply #16 on: March 19, 2008, 10:59:37 PM »
The wire coming out of the glass is fairly brittle, that's why you don't want to flex it or have it vibrate with a solid clip or solder joint - it needs stress relief, thus the plate cap.
Tubes with the thick wire out the top, 3-500Z for example you do connect directly to the plate wire, eh?  Wink
The brown crud under that plate cap is just "lamp cement".
It's a phenolic based cement.
Look it up on Wikipedia!!  Grin
Not dangerous at all...
