The Maytag's controlller board seemed to have died the first time due to a transient of some unknown origin on the power grid... it is in the City of smAlbany NY, and in that area there is mostly underground electric service, although not on evey block. So the source of the glitch is/was unknown. Could have been lightning.
The Wax motor did not die, afaik. I replaced the one on the door for good luck. They used them also for controlling the water inlet, etc... so why the others don't die, i dunno.
The controller transistor (no mosfets on the controller board) was fried as was its collector resistor... but that in turn fries the dedicated port on the microproc... no opto iso. Dummer and bummer.
She unplugs the washer when not in use now.
BUT who's to say that merely plugging it in, and out won't kill it??!!!
Well I have a back up board that does EVERYTHING except FINISH THE CYCLE!!
I mean, how wierd is that??
It will just sit there on the final "idle out spin" rocking back and forth a bit forever...
Set urself a timer and be sure to get back to the machine eventually... well it is a back-up.
See, the "timer" on these units, isn't. It actually would run through the entire cycle in about 30 seconds, if you left the power on it all the time. But that's not how it works, it is powered up by the microprocessor, then it runs to the next function, where the (duh) microprocessor senses that it has started a new function and turns OFF the stupid "timer" motor!! BUT the timer doesn't really power anything big like it used to... the microprocessor turns the motors on and off and determines their speed... the "timer" was just to keep old time housewives happy!!
Well... fun fun fun...
_-_-WBear2GCR
