In the spirit of full disclosure: I do not
like racks!
I'm using the relay rack because whenever I had "regular racks" I could never get to the jacks
in the back!! And, I never had the space to leave an aisle behind them either!
Also, I do not like screwing gear into the rack either!!
Everything there is actually on a shelf.
Rack shelves I like so far.
If I need to pull some gear out, easy-peasy!
I think I have worked out a plan for what will be essentially vestigial rails
left and right to do the slide in/out bit... unless I suddenly run into a supply
of suitable shelves on the cheap...
If I need rear rails, these aluminum racks are bolted together and even the mfr offers
them with 4 pillars - just more aluminum to bolt up!
Someone came up with a scheme where they flip the angle pieces that form the feet
and ran structural aluminum stock front to back bolted through to the upside down feet
and with the extra height added by that put on heavy duty casters! Ends up being very
close to zero clearance...
_-_-
(nice looking shack!)
