April 26, 2024, 12:47:26 PM *
Author Topic: 833A's "Low grid drive";any suggestions????  (Read 15590 times)
« Reply #25 on: March 30, 2005, 10:52:02 AM »
Quote from: WA1GFZ
I still don't understand what is is doing for you. If you reverse bias the diode the voltage will fly up. There needs to be rf isolation with the choke but a shunt path to absorb the extra bias due to drive.
I'll have to find the circuit somewhere around here or axe the Tron again when I hear him on... it's been many years since I've used it.  But it consists of only a diode and power supply choke to stop the rectified voltage from the final grid circuit charging up the bias supply caps to infinity...  :-)   There IS s a shunt feature to it as I remember.
Seems I also used a relay too, but it is foggy.
WA1HZK
« Reply #26 on: April 03, 2005, 05:43:57 PM »
Here is the Shunt Regulator that Chuck, K1KW insisted that I use in my rig after he put his blessing on the construction.
http://www.criticalradio.com/833%20Rig%20Project/Shunt%20Regulated%20Bias%20Supply.pdf
www.criticalbattery.com
www.criticaltowers.com
www.criticalresponder.com
