May 04, 2024, 01:23:59 AM *
Author Topic: Folded dipole question  (Read 16088 times)
« Reply #25 on: March 16, 2016, 02:34:41 PM »
It's good to learn new things.
There may be a reason why a folded dipole could receive less noise than a single-wire dipole. It has to do with balance and the ingress of noise (probably mostly local noise) via common-mode on the feedline (in the case of coax feed). I came across the link below, wherein there is some information on the self-balancing nature of folded dipoles. The self-balancing minimizes common-mode feedline radiation, even in the case of imbalance in the feedline/system. Less feedline radiation, and possibly the antenna balance itself, could result in less receive noise, in some cases.
http://www.hamradio.me/antennas/loop-fed-array-lfa-planar-yagi-uda.html
To answer your question Larry, I don't see any reason why a folded dipole would receive any less noise (local or otherwise) than a single wire dipole.
W2PHL
Phil
« Reply #26 on: March 16, 2016, 03:14:11 PM »
 If the folded dipole fits in the backyard and the classic dipole needs to be strung over a house, the folded dipole probably will be quieter. Experimentation is key.
I think therefore AM
