When I can't see a couple watts on ten meters and see a couple hundred on 160, this is bad.
Shane
I don't know if this is relevant, but I had a similar problem with an FT-757. First I lost 10m, then 15m. The RF output was way down on those bands. I was running mobile back at the time, and did a lot of 10FM, and AM. I'd also do some 15m AM. Turned out in my case that in the 757, the RF PA is followed by a band specific filter (half octave I think) to filter out the 2nd and higher harmonics. The parts used were not up to the task of high duty cycle modes like AM and FM. Instead of rebuilding the PCB, I bypassed it with a piece of wire! That allowed all kinds of crap into the RF output, but I regained full power on all bands that way.
I also mod'd the ALC since it based upon the built in Forward Power reading of the built in directional coupler. I merely tacked in a bigger cap across the forward power readback to lessen the peaks going into the ALC sense circuitry. This allowed me to run 100 watts FM at the edge of ALC, but with AM and SSB I could hit around 150w PEP. I am sure the IMD was terrible, but hey, it worked. :-)
Wd5JKO
