Kanthal, like I use to build my vape coils with. Good for building meter shunts as well.
Some good points...
What are the characteristics of Kanthal that would make it a good choice for a fuse? And I wonder what material they use for standard fuses?
I was also thinking about a thin piece of 60/40 solder that has a low melting temperature.
Jon, while you're in the testing mode, you might try a very thin piece of solder and see how it works.
Yes, nichrome wire is probably not a good choice since it would take forever to reach its melting point. Probably a mushy knee. I would think something like solder would have a desired fast avalanche property.
