April 26, 2024, 11:11:58 AM *
Pages: 1 [2] 3   Go Down
Author Topic: DX100 improvements  (Read 61133 times)
John K5PRO
« Reply #25 on: February 17, 2005, 07:04:50 PM »
The DX100 has turned into a fine 'phone transmitter. Following mods were done in addition to my earlier posting/list. Removed the 60:40 screen voltage resistors as those were not so effective for this particular rig. I was seeing a lot more negative modulation than positive (5-10% near full mod), and thought it might play a part. However, I also tried conventional screen choke modulation with a supplemental resistance, with less effective results. Using a dropping resistor from fixed B+ for self modulation of the screen (6146) was not effective at all.
I aborted the negative feedback around the mod transformer and speech amplifier, as it had only minor improvement, needed a lot more tweaking.
Final best setup was empircally determined:
Capacitor across the mod transformer of 0.0022 uF 6 kV ceramic.
Two 210 uf Caps for the HV, giving 105 uF total capacitance.
32K made of three 10 W resistors, 10, 10, and 12K, for the screen dropping resistor from the modulated B+. 1200 pf mica across this, and another 1200 across only 20 K of it.
Neutralization added to finals, with a wand poking through the shield from the driver tuning capacitor. (very helpful on tuning the grid and plate circuits)
33.3 volts of zener diode bias on the CT of the driver transformer secondary. 15 k resistor loading also. 750 uF 'lytic to ground.
6146 Grid metering fixed, moved clamp tube control pick off to other side of low ohm resistor.
Solid stated the HV rectifier, using Semtech SCH7500 diodes, an RC snubber across choke and MOV across primary HV transformer, per Timtron modification note. Inrush limiter on HV transformer. I left the 5R4s in the sockets for sentimental reasons, but disconnected their filaments.
The incremental results were good, and the final step was to replace the old 6146's with a NOS pair of GE 6146B's. This made a significant improvement in the peak modulation capability, and also in the carrier power. Before it struggled to produce 100 watts output on AM, and at 10 meters was less. Now it easily produces 120 watts AM with fidelity, and can go as high as 150 on CW. I can finally get 100+ positive without reaching negative limit first.
The modulators are running a lot hotter than before, like 60 mA per tube idling, and plate voltage is up around 800 and constant now. Thats a lot of power on those small tubes, but the efficiency is worst with no modulation of course. I may add a tiny Pentium CPU cooler fan under the 1625s to help out.
Proof of performance from 400 Hz to 7 KHz showed THD between 1.4 and 5% depending on modulation level. The low end suffers from inadequate iron, so at 100 and 200 Hz, the waveform is lousey. The response is very good from 200 Hz to 6 KHz, within 0.5 dB of flat from 400 Hz to 3 KHz, and is 4 dB down at 100 Hz and 2.2 dB down at 7 KHz.
The CW side of the DX 100 is still rough, having key clicks and some chirp, esp on 10 meters. But I will keep the switch on AM I think.
I plan to put this rig on the air, with little audio processing, and a jury rigged TR switching. I have nothing on AM to date, so finally....
Online Online
« Reply #26 on: February 19, 2005, 08:59:07 AM »
What ever became of Ed Sieb, VE3ES? Brian WB2JIX, has a few Apache's/DX-100's that he would like to do mods on. I told him of Ed's fine compilation and gave him his email address. He told me his email got kicked back. I think this is a fine collection of modification/theory and should be shared. Anyone know where he is?
VA3ES - Piss-Weak Ed
« Reply #27 on: March 04, 2005, 11:38:03 AM »
Quote from: W3SLK
Hi all, we're back after a long hiatus. (Don't ask!, Well you can ask, but I'll tell you in a private email, or in a PM.)    I don't know why Brian's email got kicked back;  while I do have a new email addy, all my old ones are still working.  Hmmmm...
My compilation book has been "hung up" for a few years, because I was waiting for new input from Tim, on his "new, improved, Apache/DX-100 mods" which he indicated he was going to publish, back in  January of '02.   I haven't seen those mods anywhere; still waiting on advice from Tim.
My email address has changed, but you can still contact me at
va3es<at>rac.ca
I'd love to get another edition of the "Apache/DX-100 mods book" out. Maybe I'll just reprint what I already have, and go with that.   And yes, it still includes a 90 minute tape of Tim  waxing eloquent on his theories of modifying those two rigs.
"It's been a l-o-o-o-o-o-ng time, Sonny!"
John K5PRO
« Reply #28 on: March 04, 2005, 04:00:25 PM »
I made many of Tim's suggested mods to my newly acquired and refurbished DX100. The one nagging thing about the rig is the way that Heath derived the screen voltage for the 1625 mod tubes from the center tap of the HV supply divider/bleeder. It is easy to get 475 volts across one of the 450 VDC rated 'lytics (brand new ones in mine) when modulating at high levels. I'm lucky, i suppose, in that the surge rating is 525 VDC, but i am not certain that the regular rises in voltage are considered momentary surges. As Tim says, the screen current through the bleeder/divider unbalances it significantly, both in TX1 and DX100.
The problem is worsened when solid-state rectifiers are used in place of the 5R4s. By they way, this mod is highly effective in 'stiffening' the HV supply, getting more output, and less carrier shift with mod. I tried modifying the bleeder, with a fixed 56K 10 watt resistor across the upper leg, to reduce its value slightly and unbalance the divider across the two 'lytics. This seems to help, as now the divider voltage goes from <50% of HV to above 50% as the plate switch is on and mod is applied. However, when changing the divider, the screen voltage on the 1625 is excessive, so my idling current is nearly 150 mA! This causes a dark orange on the plates and will shorten life if I leave this. I added a small Pentium PC fan at half speed (running off FW rectified 5VAC from the old 5R4 filament winding) to help move air around the modulators. I will need to play around with the resistors and lower the screen voltage. Maybe Tim's suggestion of running the screens off the med HV supply though a PTT relay are not so far out?
I am adding an audio line input connection in mine, to the second 12AX7 section, to eliminate the noisy preamp, and allow feeding balanced 600 ohm +10 dBm levels from a Volumax 4300 limiter. Does anyone have a schematic or manual for a Vmax 4300? I need to recap the thing, as it is all original from 1970. It sure has lots of 4.7 uF coupling capacitors in it.
« Reply #29 on: March 04, 2005, 05:24:02 PM »
John, are the "Tim-tron mods" you describe, the one from the AM Window site,  http://www.amwindow.org/tech/htm/dx100.htm  ?
If so, those are the ones I transcribed off the tape I have.  Tim also goes into depth about mods for the Apache, but I never got around to transcribing those.  Maybe this Spring.
WB2CAU
« Reply #30 on: March 05, 2005, 07:52:27 AM »
Quote from: N3WWL
There was also a version made for European export.  I believe the letter designater was "U".  I'm unsure of the circuit difference in the "U" model.
Hi Jay!
The DX-100U was offered well into the early 60s, possibly to utilize leftover  components after the DX-100B was discontinued in the US.  Notice also that the "U" model has 6 bands instead of 7 (missing 11m maybe?), and updated meter and knobs.  I'm guessing that the "U" designation could've stood for "universal" and might've had multi-voltage transformers but this is just my speculation (maybe they were only 230V and the "U" stood for UK).  Personally, I kinda like the newer paint scheme on the "U" instead of the 50s "science fiction theatre" look of the original.
I'm visualizing the DX-100U being used alongside the (rare in the US but plentiful in UK) RCA AR-88D receiver in a typical early 60s AM station in UK.
How come this forum (and thread) hasn't awakened any former Heathkit employees to jump in and add 2 cents?
Eric
"Life is tough, but it's tougher if you're stupid." -- John Wayne
Jack-KA3ZLR-
« Reply #31 on: March 05, 2005, 08:26:07 AM »
Hi Eric,
 Good Question, I'd be interested to hear from them as well..
Bacon, WA3WDR
« Reply #32 on: March 05, 2005, 02:35:26 PM »
I think people should try fixed or regulated screen voltage, and a moderate value resistor between the screen supply and each screen grid.  One resistor to one modulator tube, another resistor in series with the other modulator tube.  Probably about 4.7K to 6.8K in series with each screen would do it with 1625s.  If possible, to make up for voltage drop on peaks, raise the screen regulator about 50V higher, and readjust the control grid bias.
AM Press/Exchange article
John K5PRO
« Reply #33 on: March 07, 2005, 12:33:05 PM »
Ed, yes those are the same Tim Tron mods for the DX100 that I am talking about.
I made substantial gain in the problem of screen voltage on the 1625s after looking at the Apache schematic off BAMA this weekend. Seems, Heathkit engineers figured out that using the HV divider to get a cheap screen supply for the mods was a bad idea. They used a relay and ran it off the medium HV power supply, which has a different secondary voltage from the one in the DX100.
I tried it, and rearranged the power supply to lower the voltage from 380-400 on mine to about 290, with choke input instead of cap. (Another suggestion from Timtron). The modulators now have a fairly steady screen supply, and I reset the bias to 27 volts with some zeners to get an idling current of 70 mA. Tubes are much happier!  I used a Magnacraft W88 AG8 relay i had, to switch the HV to the screens (at the AM/CW switch). Mounted it in the HV side, where the former 5R4 sockets are. This gave me one more added feature, a set of NO/NC contacts for running other things beside the antenna T/R relay (like RX mute) which i wired to the rear apron accessory socket, after removing the 500 ohm audio output connections there.
Regulating 280 volts or 250 gets more tricky in the limited space i have, would need a few OA2s or a stack of zeners. I have one 200 volt motorola 1N3550B 50 watt stud mount zener which I tried on the VFO earlier, could stick someone on the end of this to get it up to 250 or so.
I am interested in hearing how much success people have gotten with adding feedback around the modulator, either from the 500 ohm tap back to the front end, or just around the 12BY7 triode-connected driver. I need to try it, as part of the quest for East Coast sound, although I am in the Southwest.
« Reply #34 on: March 07, 2005, 08:05:48 PM »
If you are going to mess with a triode connected 12BY7 consider using a 12B4 instead. You won't find a miniature tube triode with a lower plate impedance, a must for good dynamic regulation and the resultant low distortion drive.
John K5PRO
« Reply #35 on: March 08, 2005, 06:15:18 PM »
Steve - last night I did just that. Strange you should mention it, I noted the 12B4 was the minuature version of the old 6B4G and 2A3 in my RCA tube databook. I made a special socket adaptor so I could A/B test the two tubes as drivers in the DX100. It is a 9 pin tube plug and socket mounted vertically, so that I could make the wiring changes in the adapter. There are only a few wires needing to be moved to fit a 12B4 into 12BY7 socket. Both tubes look incredibly similar, and have same filament ratings.
What i discovered is that the 12B4 does provide better drive to the 1625s when grid current flows in AB2. The 12BY7s crapped out about 50 V p-p on each grid. The 12B4 went out to 100 V p-p before noticable distortion cropped up. It does have lower gain however, and the 12AX7 is required to run at higher levels to make up for it. Oddly enough, the overall THD (without feedback) is best with the triode connected 12BY7, not the 12B4! It was consistently better. I think the 1625s and mod transformer crap out before the difference in drivers is noticable.
I added Neg feedback from the plate of the 12BY7 to the plate of 12AX7 #2, through 200 K and a 0.33 mylar cap. The DX100 is very sweet now, with THD running about 0.25% across the band up to 80% mod. It didn't required global feedback around the mod tranny.
Also I spent the time to try adding the series R to the screens of the 1625's as suggested here. Very slight improvement, but the loss in power
made it impratical since I am running only 300 V for the LV now, and using it for the screen supply. I tried as high as 4700 ohms on each tube, in many steps from 910, 1200, 1500, 2200, etc. I ended up pulling it out and adding a simple 10 ohm to each screen as a place filler in my chassis.
 The biggest improvement by far was to lower the output Z of the 12BY7 and leave it in, with the NFB i mentioned. I think I'm done with the DX100 mods, unless I can find a better turns ratio mod transformer that fits. I am hooking up an old UTC VM4 tonight, to empirically find the best match, and see what it comes up with.
« Reply #36 on: March 08, 2005, 08:59:29 PM »
Very interesting. Just goes to show you, it's the complete system that counts, not one component or section of the schematic. Sounds like you have the DX-100 sounding about as good as it can without major surgery like a different mod tranny and driver tranny (or elimination of the driver tranny and some direct connect approach). Probably not worth the effort, unless as a learning exercise.
Have fun with the Dixie 100.
John K5PRO
« Reply #37 on: March 09, 2005, 02:52:26 PM »
Correction to my last posting: The THD figures are 10x what I said, not 0.25% but around 2.5% and higher. Oops, cockpit error. Still I swapped the 12B4 in and they got worse. Stick with the 12BY7.
K6IC
« Reply #38 on: March 09, 2005, 03:00:30 PM »
Hi John,
Havva couple of DX-100's,  like 'em,  and have thought that for their weight class they do a very good job and seem quite bulletproof.   The Apache TX-1 is prob a bit more sophisticated,  but lacks 160 Meters.
Thanks for all the info on your progression of mods,  and for starting this thread.
C U on the Bands,   DE   Vic   KF6RIP
John K5PRO
« Reply #39 on: March 11, 2005, 03:05:35 PM »
I'm addicted to playing with this thing. The XYL thinks so. She keeps hearing tones and bleeps in the late night hours. The dawgs are restless too. For me its a learning experience on RC coupled audio amps and pentode/beam power tube modulators. Triodes in class B are so much simpler and sweet sounding...  My first AM rig was an Apache though, when I was WN4PRO, over 30 years back.
I tried out a UTC VM4 modulation transformer, massive 300 watt thing, in place of the stock Heathkit tranny. Walked it around all of the ratios from 1.5  - 3:1. Then discovered that the VM4 was breaking down, could smell ozone and also hear audio arcs inside. Switched to my newer CVM4, and as expected, the bottom end is quite extended on the DX100 with it. It buzzes my speaker when I tone modulate it. However, also found that big iron was quite distorted at around 5 KHz, at greater than 50% mod. Almost seemed like the modulator was breaking up. Possibly a parasitic? I had 12 inch leads going out of the chassis and from the plate caps out to the remote ungrounded transformer. I was careful not to touch anything while testing but the power switch. The test confirmed that the 8000 ohm primary impedance of the Heathkit transformer is limiting peak (pos) output of the 1625s. (2.86 ratio). At a more optimal 6900 ohms, there is slight improvement. At lower Z, the modulator crapped out with higher distortion. Other night I finished solid stating the power supplies, replacing the 6AL5 with a pair of 1N4005 diodes for bias. Now I have space all over the place for 'improvements'. This DX100 isn't ever going to be converted back to stock. Since the CW mode is limited by the marginal VFO stability and clicks and chirp, I removed the phone jack for the key, installed a stereo (tip, ring and sleeve) phone jack in its place, and ran shielded audio cable over to my UTC A21 line input transformer which has been mounted beside the audio driver transformer. Now i have a convenient way to stick in processed audio at 0 dBm levels without using that first 12AX7 noise maker.
Another small but significant improvement came about after realization that there is no such thing as matched JAN-1625s, due to the vintage of the tubes and that most of them being used are either NOS or used in Korea. I stuck a 50 ohm cermet pot on a bracket, and fed the wiper to the modulator cathode current shunt, and each end to the cathodes of the tubes. With this in place mounted next to the shielded audio compartment, I am getting about +3 volts of self bias for 120 mA peak current in each tube, added to the -26 volt zener regulated bias on the grids. Injecting a 1 KHz tone at 80%, there is a definite null in distortion that can be found.
With all this said and done, one appreciates why the Apache used EL34/6CA7s instead of 1625s. They are rated for 800 volts, have substantially more emission and cathode current capability. If I tap the secondary of the DX100 mod transformer at the 500 ohm point, ratio changes to 3.48, which would present about 10K to the modulator plates for a nominal 130 watt RF output. 6CA7s need 11K for AB2 at 750 volts to deliver roughly 100 watts. The Apache has the correct iron for that. Johnson, of course, went the 6146 modulator approach, and that is certainly an option but it  needs a 6K transformer, or lower even.
« Reply #40 on: March 11, 2005, 07:28:05 PM »
Wow John, talk about re-engineering.  You gonna furnish a kit?  How much improvement in THD from stock is there?
Bacon, WA3WDR
« Reply #41 on: March 11, 2005, 08:28:59 PM »
I noticed significant high-frequency distortion from my VM-5.  Looking at the waveform, it appeared to me that the upper half of the waveform was slightly delayed with respect to the lower half.  With a high frequency tone, I saw a big crossover distortion on the rising side, but none on the falling side of he waveform.  I don't have the VM-5 any more, but I suspect that the problem was unequal leakage inductance in the two halves of the primary winding.
I saw a similar, but lesser high frequency effect in my A-3894 transformer.  I reduced this distortion substantially by introducing delay in the less delayed half-cycle at the phase splitter.  I just put a small capacitor from one output of the phase splitter to ground. Of course, this isn't possible when a driver transformer is used.
It might help top-end distortion to try a small inductance, probably in the range of 5 to 20 millihenries, in series with one plate lead to the VM-4. If it makes high-end distortion worse, try it in the other plate lead.  Has anybody ever tried this?
Watch the voltage ratings, because the inductor will be at modulator plate potential, and also there will be some inductive kick from the pulsing class B current.  Also the little inductor needs to handle half of the push-pull plate DC.
John K5PRO
« Reply #42 on: March 18, 2005, 12:47:17 PM »
I tried two new pairs of modulator tubes in my DX100 'test bed'. Built a dummy load out of parallel 25K and 10K ohm 100 watt resistors to simulate various RF stage loads on the secondary of mod tranny. Goal for each was to reach 120 watts into an optimal load, with reasonable distortion numbers. I was able to coax 110 and 115 watts from each pair. The 6CA7/EL34, 6146A and 6146B were tested in AB1 class, no grid current, eliminating the stringent requirement of having low output Z for the driver (12BY7 or 12B4 depending on which I was using).
Calculations of the preferred plate to plate load Z for EL34s and the Amperex and Telefunken datasheets showed needing about 10-11K for full output (100 watts) with 800 volts of Ep, 400 of Eg2. Measurements proved that wrong, as i saw 25 watts of undistorted power with this impedance presented to the plates. When i went back to using the full secondary winding of the DX100 transformer (2.86 Z ratio) and played with many combinations of resistors, I found that 8500 ohms is about optimal for these pentodes. I wonder why there is a discrepancy on the datasheet,all manufacturers copied it.  Thats exactly what the DX100 transformer presents to the plates if you load it for about 130 watts output. After tweaks to get about 38 volts of neg bias on the grids, and a solid 400 VDC on screen, the EL34s really worked well. This is far from the operating point that they see in a TX1 Apache however, with the 3K:11K transformer it has. THD is 1-2% for 50% mod, and rises to 4-5% at high mod. No feedback yet. Running up to class AB2, the distortion rises slowly, and even clipping is relatively 'soft'. Screen current is about 25 mA for both tubes, higher at 100% mod. Best idling current (Ip) is about 60 mA.
With 6146A, the optimal Z is lower, similar to the 6K or so on the datasheets perhaps. I tried 8500 again, and it played fine. The bias voltage is higher (42) for idling. Eg2 is only 200 instead of 400. Used an external power supply to fine tune screen voltage. THD is slightly better in mid band, but the low end of modulation capability is more limited, as the transformer effect (distortion) was worsened when using the beam power tetrode style tube. I tried a pair of 6146Bs but the bias voltage needed to be near 50, difficult to reach in the DX100 without more changes to the bais resistor string affecting other stage bias too. Audio was similar with the B's to the A's. 6146s had a harder clipping point, probably where the plate voltage swings below screen, and the beam forming plates are not doing the same function as suppressor grid in the pentode, to minimize secondary emission at the screen. Also, the effect of AB2 operation is more noticable with the 6146 on the scope.
In addition, getting 6146s to fit into the ceramic octal sockets that were used in replacement for the 1625 sockets, was tricky. I reused the sockets from the now gone 5R4 HV rectifiers. The holes for 6146s would have to be cut much bigger diameter to allow these fat tube bases. So I used some Vector tube extender adaptors, which raise them about 2 inches. Changes to the wiring are small, as both tubes are nearly the same, except for screen and plate connections, as long as the wiring to the cathode/suppressor is chosen to be the common pins for both types.
Filament current (1.25A) of the 6146 style favored it over the EL34 (1.5 Amps) when reusing the DX100 filament tranny winding, which is only good for 4 ampsl.
I stuck with the EL34s for now, and have optimized the situation to get best audio performance with them. They don't have the vintage plate caps, but they also don't need a separate zener regulated 200 volt supply for G2, and can use the low voltage B+ (~400 if using the stock filter arrangement with capacitor input, and solid state rectifiers) through a relay linked to the HV switch.
Next week, I plan to test a multitap SNC modulation transformer that I just got off Epay, to fine tune things. The amazing thing is that the Heathkit DX100 transformer has held up to quite a bit of tone testing at 90% modulation. Adding a Modified Heising choke and capactor would improve things immensely all around, esp the low end. I read on Peter Dahls transformer listing that his Apache modulation iron is heavier and larger, but I am not certain if the Heathkit original is also.
It appears that using 6CA7/EL34s in the Apache is less optimal for high peak and low distortion modulation. The lower impedance ratio of the DX100 mod transformer works fine.
John K5PRO
« Reply #43 on: March 28, 2005, 07:16:08 PM »
I hooked up the SNC 5P532 modulation transformer I got off epay (it was unused new old stock in the box, probably from the 1950s - a good vintage to stick into a DX100). First tested the 2.84:1 Z ratio which is nearly same as the stock DX100 iron. This proved to be uneventful, except that the SNC makes more noise (talks back) and is bigger and has a bold 'bottom end'. I was getting about 120 watts with 8500 ohms transformed back to the pair of EL34s. THD and response was darn good, like 2-3% at mid band, and worse at the ends - esp the bottom. Response was nearly flat (+0/-0.5 dB) from 100 Hz to 10 KHz!
Switched to 2.12:1 Z ratio which would be ~ 6.5K for the pentodes. Power came up, THD slightly worse. Could get about 1850 V p-p audio, which would give it a lot of positive modulation capability. The audio was providing 130 watts of sinewave with good performance into a load.
Then I tried a ratio < 2 and the THD was worse, the modulator was screaming at me, got 2 kV p-p audio across an equivalent test load. This was pushing it far, the positive capability is nearly 150%.
For a while I tried pulsing audio bursts to see what sort of tilt and overshoot the rig had, but the torture test opened my 25 ohm cermet pot in the cathodes of the pentodes (my distortion null/balance pot).
Hooked up the secondary to the mod transformer to the 6146B DC feed, and processed my voice from a microphone with a CBS Volumax to limit the negative peaks to under 100% to protect the transformer. It confirmed the peak capability for 2.12:1 ratio (125% positive reachable) and at 2.84:1 (115%).
I plan to test the rig with the stock transformer once again, now that i have the audio processed from a mic as well as tones. I can live with 115% positive and occasionally higher peaks. It would be a lot easier to use the little black Heathkit tranny than to kludge in the SNC, it does't fit.
I did note that the EL34s are quite picky about their screen voltage, and 400 is much better than 380-390 for lowest THD/IMD. These tubes like it hot. But I could not let them soar up to 430 volts when the HV is switched on and there is no audio. Cutoff bias was then inadequate and a warm orange glow appeared on one plate. As the heated the idling current rose, and they tended to want to run away slowly. To stabilize things, I came up with a very simple screen voltage series regulator which should be of benefit in pentode audio amplifiers where there is no chance for reverse current out of the G2 element. It consists of an 800 volt IRF820 mosfet, connected drain to the power supply (varying between 405 and 445 volts)  and source to the pentode screen grids. A 20 K 1% resistor runs to the gate, which is grounded via a 400 volt leaded zener diode. This regulates the screen close to 402-403 volts over power supply variations and with 0 - 50 mA screen current variations.
Thats about all, the DX100 project appears to be nearly done. As soon as I finished the audio chain I hope to try 75 and 40 in the late afternoons or mornings to get some on air experience with it. I am hearing a lot of Texas, Arkansas, Oklahoma, Colorado, Arizona, and CA from my locale near the Rio Grande.
« Reply #44 on: March 28, 2005, 07:50:02 PM »
Very cool, John.  Now you need to write the whole thing up in an article that Gary can post on the AMFONE part of this site, or HUZ man can put on the AM Window.
73 John
John K5PRO
« Reply #45 on: March 31, 2005, 02:33:56 PM »
Putting this thing to bed now, after all the open loop measurements, time to close negative feedback loop and see what that does. Running the DX100 mod transformer is not quite as nice as the SNC transformer, with respect to THD and response, but its a compromise. I can still get 115% positive modulation using the 6CA7/EL34s, they have a lot of cathode emission!
Last night though, fireworks in the shack. Boom. Pow. Oh crap, I thought I had destroyed my Heathkit, at least the HV supply. Plate current was pegged, and it would blow the line fuse (5 amp fast blow) quickly, not to mention loading down the 800V to about 600. I unhooked the yellow wire from the power supply to the CW/PHONE switch, and it worked fine unloaded. Relief! Then I high potted the HV lead to the finals but my 450 volt power supply didn't uncover any shorts to chassis. I hooked it back up, must be a defective 6146B? I had been running this thing on its side for a month, at high power with high modulation, so it was a possiblity that I had a plate to suppressor or screen short. Tried another tube, same explosion. Went back to an older 6146, same thing. This time it left a smoke trail though. Turns out I had not calculated the voltage rating for a 1500 pf mica cap I put across the screen dropping resistor for the finals. I just stuck a 500 volt cap in, thinking the screen voltage was only concern. That capacitor is used for high audio frequency phase compensation for the screen bypass. 1500 seemed like the best value for THD for both 1 and 5 KHz audio. That capacitor has the brunt of the modulated B+ coming in one end, which is 800 + 950 (for asymetric peaks) and about 185 on the other end at the 6146B screens. Lets see, thats over 1.5 kV across a 500 V cap! Duh.
The transmitter survived the ordeal, which says good things for the solid state rectifiers as well as the screen grids of my 6146Bs. They took quite an overload for a few seconds each time I tested. while at it I thought about the peak voltages and replaced the main plate bypass cap, one of those red mica things which is marked 0.001@2kV. I used a ceramic doorknob, type 858, 1000 pF@5kV. It measured capacitive on the vector impedance meter up to 29 MHz, so is perfect for this application - and has a lot more headroom for peak voltage.
John K5PRO
« Reply #46 on: April 04, 2005, 07:33:16 PM »
The DX100 got negative feedback installed, overall loop from the 500 ohm tap, through a divider made of series 450K HV resistor plus a 39K 1/2W to gnd. This reduces the DC component to 68 volts, allowing a large electrolytic in series to block it from biasing the cathode of 12AX7A stage #2. If I used a ceramic capacitor for HV rating (i.e., 0.01 - 0.05 uF 1.6 kV),its application in the feedback would give a bass boost. With the wimpy DX100 mod tranny, this isn't a great idea although it can be 'xperimented' with using audio shelving EQ later.
With these components i have about 6 dB of moderate feedback. This lowered the THD to 1.5% typical at 50% mod, and about 3% at 80-90%. The freq response is nearly board flat to 10 KHz, with slight rolloff at 100 Hz and below.
I am toying with the idea of installing a small filament transformer (6.3@0.3A) that I found at Ed's Black Hole last week. It would power only the 6AU6 VFO regardless of whether power switch is on, similar to what Apache did. I am wondering if long term stability would improve with this? Already have the VFO tube running off 150/110 volts DC regulated now instead of 400/150 as original DX100. There is room next to the LV choke under the deck near the LV power supply cap.
« Reply #47 on: April 04, 2005, 07:42:28 PM »
Hallicrafters did the same with the SX-101 and SX-115.  They also  bolted a power resistor to the chassis continuously powered off 110 to keep the surrounding components warm and dry (damp basements apparently being an enemy of stability in the 50's and 60s).
73 John
« Reply #48 on: April 04, 2005, 10:48:56 PM »
John, Have you rechecked optimum load impedance with the feedback loop in use? Great nuts and bolts writeup.
« Reply #49 on: April 04, 2005, 11:33:36 PM »
This has been an excellent series, and  a real boon to us DX-100 fans.  I've copied all these posts, and will certainly use the info when I next upgrade my DX-100's.
Thanks John.
Pages: 1 [2] 3   Go Up
