I"ve never owned a Valiant, but I'm going to go out on a limb and wager that Johnson used the same Potter and Brumfield relay in the Valiant that they used in the Ranger — it's an LM11-10000. The coil has 10K ohms DC resistance. About the only source is going to be from a junker.
In the Ranger, it's powered with around 160V off of a divider on the 300v supply. I think you'd be better off using a 12V relay and a voltage doubler from the filament line. I was about to do that in my Ranger II when an original (used) relay unexpectedly materialized from an ancient "wanted" post ..
Grant NQ5T
Thank you Grant,
Yes, unless one turns up soon, I think I will do just that.
Rich
