I bought a bunch of Eveready AA alkaline batteries a couple of weeks ago. They were fresh batteries with a 3/18 use by code. I put 10 in a series connected battery holder for later use. Tonight, I was sitting nearby and I began to hear a sizzling, crackling noise and noticed an acrid smell. After looking around I found that the noise was coming from the battery holder. One of the AA cells was hot and leaking. None of the others were even warm. I replaced the bad cell with another and the problem did not repeat.
I've never seen this before. Do batteries occasionally develop internal shorts and boil themselves to death?
Ed
I think that question was answered. Did you successfully return the battery for a replacement or did its disposal method prevent that?
What does one do, besides moving away, when a primary battery is doing this? If it explodes, someone could be hurt, but they have vents. They can be very hot though. On the other hand, a piece of equipment could be damaged or it could spray chemicals everywhere.. At what point, if any, should someone try to retrieve the cell and place it in a safe area?
This may be one reason why YLs don't usually like projects on the dining room table.
