Good info. I learned alot. The 6336/500 trans is the big one. Some T3s had different transformers. You can see his in the manual, they are listed. from memory, its 110 volt primary. Its a beast. I ran my T3 all night and had a failure when I first put it in service.. I slid the deck out with a friend and we found a bad Rectumfier. I put in solid state plug ins. The Power trans was cold. 500MA CCA. For that combo of tubes.
c
Clark, the Industrial Transformer Corp.-built T-368 6336 VAC CT at 500 MA plate tranny I had in my older single 4-400A rig had a 120/240 VAC primary. I ran that xfmr on 240 VAC.
Bruce
