km1h, what is the advantage of a 2n5109 over a 2n3866? the only differences i see are that 2n5109 is rated for 1w of power dissipation whereas the 2n3866 is rated at 5w and the 2n5109 seems to have a higher minimum hfe. anything else? would i be able to get a higher gain with a 2n5109?
The 3866 is rated at 1W out in Class C while the 5109 designed as a Class A CATV amp wil double that in Class C and have about 1.5dB more gain. Ive also found it easier to stabilize even tho its Gbw is higher
carl (km1h), would a ferrite bead on the base potentially eliminate the feedback without limiting gain at higher frequency (unlike a feedback capacitor.
That depends upon what you mean by higher frequency. If you use the minimum ferrite to eliminate a VHF parasitic then it should have no loss effect at HF. One tiny FB43-101 may be all it takes. They also work on the other leads.
