This is either Hammy-Hambone or really neat.
I was rebuilding an old BC/SW set from the 1940's. It had the 'green dot' disease, this is where various parts of coils develop bright green copper oxide deposits which usually means the coil has opened up. I needed to replace a small coil used in the 'wave trap' on this set. I had tried rewinding the original on the cardboard form but no joy. The old form just wasn't up to the task, and my coil winding did not look so good, more importantly it also didn't work
. The original used Litz wire, a very fine multistrand magnet wire, and I couldn't fit enough regular 30 awg on the form to get into resonance.
Replacements being hard to find, what to do? Well my wife sews a lot of stuff... so I 'borrowed' one of her cheap plastic bobbins used for holding the thread under the needle. Looked to be about the perfect size, and the repair would be under the chassis, invisible, so as long as it worked it would be ok fine.
Sure enough, after a bit of cut and try to get the frequency adjusted, it works!! A little bit of epoxy to hold the bobbin to the original solder tab mounts on the trimmer and we're back in business!
This success got me to thinkin' - stack these guys on a 1/4 inch dowel and you could make up a really nice Pi-wound choke for pennies!
