April 27, 2024, 02:24:47 PM *
Author Topic: How to add an RF protection device to amplifier?  (Read 15115 times)
KA2QFX
Mark
« Reply #25 on: March 17, 2011, 08:06:54 PM »
Tom,
You still have a problem. Steve's board is a wonderful circuit but as I recall is tracks the current vs. voltage from the modulator stage. If either one falls out of the comparator window the circuit "trips".  I suppose you could compare final PA current to a non-varying reference voltage if you reduced the sensitivity of the comparator. A question Steve could easily resolve.
But you still need a way of detecting the reflected power and something for either condition to act upon to shut-r-down.  Speaking of "r". Did you name this contraption yet?
Mark
« Reply #26 on: March 17, 2011, 08:31:11 PM »
Mark,
Good point about the current vs: voltage tracking.   Yes, maybe if the Voltage is set to a certain threshold value, the current will hit the desired preset point and trigger the comparator. I think that wud work, but Steve wud know for sure.  I need a trigger at above 10A at 30V.
The LP Filter has a reflected SWR output, so I'm all set there.
I plan to use the overload hi or lo to trigger a SS device to shut down the amplifier bias or PTT circuit voltage.  No relays involved.
